Results 11 to 20 of 21
October 9th, 2010 10:11 PM #11
can anyone recommend a shop * or near banawe for headlight alignment?
- Jan 2006
- 28
December 8th, 2010 06:54 PM #12totoo po yan sir, hindi maganda ang alignment sa L.A. Cars, 3x ko na nadala ang ride ko, ung last tym nga gabi ko pa dinala para mas direct sa road ang adjustment, kaso lang, medyo na-align lang ng konti pero ang problema naman, masyado ng lumubog ang projectors ko papasok dun sa frame nya, mga around 3/4 inch din ang lubog from the bezel, so ang naging effect nya, kulang tuloy ang light nya sa sides ng ride ko since masyado na syang pumasok, may maire-recommend kaya ang mga gurus dito na specialists sa projector alignment, nagsasayang lang kasi ako ng fuel papunta sa L.A. Cars pero walang nangyayari, sobrang trapik pa, please help me naman, iwas na lang sa shop na to kung alignment ang papagawa nyo...
- Dec 2002
- 2,335
December 9th, 2010 03:47 PM #13Mukhang may ibang factors na hindi na di-discuss. The original bulbs installed are halogen bulbs and the projectors were designed for these bulbs. The cutoff is very visible pag halogen bulbs ang nakaka kabit and madali adjust yan. Pag nagkabit ka ng hid bulbs, magkakaroon ng glare above the cutoff kahit projectors yan, meron light scatter above kasi 3x more light being produced by the hid bulb so tricky ng konting yung adjustment pero pwede naman. Ginagawa dyan ng iba to compensate for this, binababa yung adjustment so meron disadvantage coz yung throw mag su-suffer naman. Kailangan alam nung nag a adjust yung theory kasi pag ginamit yung machine magkakaroon ng konting fault kasi meron light scatter. Going back to your question, autotecnika I heard nag aadjust. I cannot vouch for them kasi I've never tried them pero meron akong kilala who availed of their services. FYI, yung picture sa baba, hid projector yan with hid bulbs so very clear ang cutoff.
- Mar 2010
- 16
September 30th, 2011 01:17 PM #14Hi All. I have isuzu alterra. I have something removed from the inside of the projector to make the light pass through all the way up. but ngayon nagsisi ako dahil sobrang taas. gusto ko sanang bumaba.
questions
1.) pag set mo pa baba ung projector, sasama bang bababa ung high beam?
2.) parang d na xa gagalaw pag twist ko ung dalawang adjustment points. Kahit gaano ko iikotin.
Please help. thanks!
- Dec 2002
- 2,335
September 30th, 2011 07:49 PM #15kwo: that bulb cover is designed to limit the output of the halogen bulb so that it will not go to places sa reflector bowl that can coz glare to other motorists. there is a reason kaya nandun yun. kaya sobrang tumaas output of the halogen bulb is now being reflected all over sa reflector bowl. sa questions mo;
1. anong model ng alterra. Pag single bulb ka lang then for sure pag baba ng LO, baba din yung HI. even yung mga meron separate bulbs for LO and HI isa lang ang adjustment nun.
2. pwedeng naupod na yung plastic insert sa loob kung saan naka pasok yung adjustment screws. It is not designed to be adjusted everytime, plastic lang yun.
Hanapin mo yung tinanggal sa headlight mo. Ibalik mo and solve problems mo
- Mar 2010
- 16
September 30th, 2011 08:33 PM #16
September 3rd, 2013 11:00 PM #17
Buhayin ko lang 'tong thread na 'to. Any alignment centers near the east side of Manila? (Pasig, Marikina, Antipolo, Katipunan etc). I've tried DIY'ng my alignment but to no avail. And how much would this service usually cost? Thanks!
- Apr 2018
- 12
June 6th, 2019 07:55 AM #18Up ko lang ito. Ano po ba option ko sa pag-align ng projector headlights? Aalisin ko na yung DIY kasi gusto ko precise yung gawa. I don't think kung i-DIY ko precise ang resulta.
1. Casa?
2. Yung mga nagreretrofit ng HID shops?
3. Kung wala talaga DIY ko na lang
Takot ko lang sa casa baka hindi pumayag galawin, since yung projector ko galing sa TOTL variant ng Mirage. Eh yung Mirage ko base model lang (yung TOTL Mirage HID projector HL, yung base model reflector).
June 7th, 2019 04:09 AM #19
Pina ka luma na alignment menthod is at 25ft the cut off of your headlights shouldn't be higher than a normal sedan's side mirror. Tested and proven na yan even the internationally known retrofitters like trs or lightwerkz ay ganito parin ang advise sa mga diy'ers na walang special equipments or walang basehan since dapat bago ginalaw ang headlight mo dapat minarkahan muna sa isang wall Ang stock cut off while yung car ay naka park on even surface.
Sent from my CPH1809 using Tapatalk
- 52,731
June 7th, 2019 04:35 AM #20many headlights can be aligned, DIY. it's not difficult.
the special instrument required is usually a long phillips screwdriver. lookit your car, po, and see how long it should be and how fat the shaft mustn't be.
the most difficult part, is to find a suitable area... flat, preferably concrete surface, and a wall some meters away. google the aiming recommendations, po. i usually do my alignments in the workplace parking bldg, at night, when everyone has gone home. ilang beses nakong napag-kamalang may sira kotse...
but if you prefer others to do the aiming, i am sure they will be happy to be of service. your retrofitters should do it as part of the service.
Xiaomi E-Car
