Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2005
    I've just had my Montero Sport's headlamps replaced by HID xenon bulbs but the aim of light seems not properly aligned. The shop technician where I had my bulbs replaced can't properly set them to its proper aim adjustments.
    I already tried DIY at home but unfortunately, I cannot set them to its right settings for already 2 days. Now, I've decided to just look for a shop/technician who can do the job right away.
    Can anyone suggest/recommend me to a good shop?
    TIA
    Quote Originally Posted by rostum View Post
    TIA
    L.A cars should be the perfect place for you need.
    they offer laser alingment.
    go to this site
    http://lacaraccessories.com/index.ph...d=42&Itemid=82
    HTH.
    just an idea from the net:
    TO AIM PROJECTOR HEADLIGHTS:
    1. Align your car dead center in your driveway....the front and back of your car need to be perfectly aligned in the center..
    2. Pull your car up to the garage door...as close as you can get w/o hitting the door..dead center in the middle of the garage door / driveway.
    3. Put a piece of tape where the headlight beams hit the garage door. This should only be smal dot of light...
    4. Pull you car back 25'. Your Projector lens should be 25' away from the garage door...not your tires or your bumper...your headlights. DEAD CENTER IN THE DRIVEWAY
    5. With tape Place a VERTICAL line that intersects each piece of tape that you put on the garage where your headlight beams hit. Use a yardstick or a straight edge t make it perpendicular to the driveway. This is important for aiming your lights right to left....this is just as important as up and down because if your lights are aimed to far left you will still be shining omcoming traffic in the eyes and if they are aimed too far right your not getting the most out of your light.
    6. With tape place a horizontal line along the garage that intersects each piece of tape that you put on the garage where your headlight beams hit. They should oth be the same height off the driveway.
    7. With tape place a horizontal line along the garage that is 2.1" lower than the tape you placed on the garage in instruction #6. This line should be parallel with the line in #6...just 2.1" lower.
    8. Cover up the passenger side headlight with a thick towel.
    9. Turn on your lights
    10. Drivers Side UP/Down: Bring the lower step of the cutoff to or below the tape line that is 2.1" lower than your headlights...Dot Spec is 2.1" to 2.5" drop over 25'
    11. Drivers Side Right / Left: The Vertical line on the drivers side of the garage should intersect the middle of the slant on the cutoff. Move the beam pattern until this is the case.
    Moving the projectors from right to left may effect the height of the beam pattern. If this is the case..just go back and fine tune.
    12. Cover the Drivers side headlight with a thick towel.
    13. Repeat the UP/Down Left/Right procedure that you did on the drivers side with the passenger side. The vertical line on the passenger side of the garage is to be used for instersecting the slant in the cutoff on the passenger side headlight beam.
    what makes this difficult is looking for the location where you can do it privately and the road must be level.
    Jul 2004
    Try Autotechnika at the Fort. They also have that alignment service. As much as possible I don't recommend LA Cars.
    if you are at the south area. i've seen a shop earlier in motortown atc who does HID alignments. nasa gitnang part yung shop, i just forgot the name. check mo na lang yung parang signboard nila dun. they offer alignment services ng HLs.
    Aug 2009
    nag aalign din ba sila ng headlight na HID yung bulb? hindi clear type
    ibig sabihin nyan di magaling ang nagkabit ng HID mo or di maganda yung brand ng HID mo.
    yung Trooper ko at FD pina HID ko hindi nabago ang alignment.
    autotechnika din ang shop na i rerecommend ko
    Jul 2006
    sa may qc area meron po ba? kasi i'm planning to change the bulbs of our Montero Sport when it arrives later this month. And how much will it cost?
    may i recommend ako sa iyong seller ng HID, very reliable at madaling kausap ang seller. kahit Montero Sport ni Vice Ganda sa kanya nagpakabit. madali siya kausap pagdating sa warranty.
    http://tsikot.yehey.com/classifieds/showproduct.php/product/108108/cat/48
    eto naman website nya. www.lxsunworx.com
    dami na niyang Montero Sport na kinabitan ng HID
    Jul 2006
    hindi naman po seller ng HID tinatanong ko po. yung pwede pong mag-align ng projector headlight ng Montero Sport ko after ko magpakabit ng HID. Kasi I'm deadset on Xenonworx because of its 30 months warranty. meron po ba sa quezon city area na alignment expert?
    can anyone recommend a shop * or near banawe for headlight alignment?
    Quote Originally Posted by glntVR View Post
    totoo po yan sir, hindi maganda ang alignment sa L.A. Cars, 3x ko na nadala ang ride ko, ung last tym nga gabi ko pa dinala para mas direct sa road ang adjustment, kaso lang, medyo na-align lang ng konti pero ang problema naman, masyado ng lumubog ang projectors ko papasok dun sa frame nya, mga around 3/4 inch din ang lubog from the bezel, so ang naging effect nya, kulang tuloy ang light nya sa sides ng ride ko since masyado na syang pumasok, may maire-recommend kaya ang mga gurus dito na specialists sa projector alignment, nagsasayang lang kasi ako ng fuel papunta sa L.A. Cars pero walang nangyayari, sobrang trapik pa, please help me naman, iwas na lang sa shop na to kung alignment ang papagawa nyo...
  13. #13
    Mukhang may ibang factors na hindi na di-discuss. The original bulbs installed are halogen bulbs and the projectors were designed for these bulbs. The cutoff is very visible pag halogen bulbs ang nakaka kabit and madali adjust yan. Pag nagkabit ka ng hid bulbs, magkakaroon ng glare above the cutoff kahit projectors yan, meron light scatter above kasi 3x more light being produced by the hid bulb so tricky ng konting yung adjustment pero pwede naman. Ginagawa dyan ng iba to compensate for this, binababa yung adjustment so meron disadvantage coz yung throw mag su-suffer naman. Kailangan alam nung nag a adjust yung theory kasi pag ginamit yung machine magkakaroon ng konting fault kasi meron light scatter. Going back to your question, autotecnika I heard nag aadjust. I cannot vouch for them kasi I've never tried them pero meron akong kilala who availed of their services. FYI, yung picture sa baba, hid projector yan with hid bulbs so very clear ang cutoff.
    Hi All. I have isuzu alterra. I have something removed from the inside of the projector to make the light pass through all the way up. but ngayon nagsisi ako dahil sobrang taas. gusto ko sanang bumaba.
    questions
    1.) pag set mo pa baba ung projector, sasama bang bababa ung high beam?
    2.) parang d na xa gagalaw pag twist ko ung dalawang adjustment points. Kahit gaano ko iikotin.
    Please help. thanks!
  15. #15
    kwo: that bulb cover is designed to limit the output of the halogen bulb so that it will not go to places sa reflector bowl that can coz glare to other motorists. there is a reason kaya nandun yun. kaya sobrang tumaas output of the halogen bulb is now being reflected all over sa reflector bowl. sa questions mo;
    1. anong model ng alterra. Pag single bulb ka lang then for sure pag baba ng LO, baba din yung HI. even yung mga meron separate bulbs for LO and HI isa lang ang adjustment nun.
    2. pwedeng naupod na yung plastic insert sa loob kung saan naka pasok yung adjustment screws. It is not designed to be adjusted everytime, plastic lang yun.
    Hanapin mo yung tinanggal sa headlight mo. Ibalik mo and solve problems mo
    model ng altera ko 2007, bale projector type na xa..separate bulb ung high beam n xa..same lng ba ang adjustment sa projector at high beam? kahit separate?
    gusto ko sanang ibalik ung tinanggal kaso gastos nanaman
    Quote Originally Posted by garyq View Post
    Jan 2013
    Buhayin ko lang 'tong thread na 'to. Any alignment centers near the east side of Manila? (Pasig, Marikina, Antipolo, Katipunan etc). I've tried DIY'ng my alignment but to no avail. And how much would this service usually cost? Thanks!
    Apr 2018
    Up ko lang ito. Ano po ba option ko sa pag-align ng projector headlights? Aalisin ko na yung DIY kasi gusto ko precise yung gawa. I don't think kung i-DIY ko precise ang resulta.
    1. Casa?
    2. Yung mga nagreretrofit ng HID shops?
    3. Kung wala talaga DIY ko na lang
    Takot ko lang sa casa baka hindi pumayag galawin, since yung projector ko galing sa TOTL variant ng Mirage. Eh yung Mirage ko base model lang (yung TOTL Mirage HID projector HL, yung base model reflector).
    Mar 2012
    Quote Originally Posted by Teaspoon View Post
    1. Casa?
    Pina ka luma na alignment menthod is at 25ft the cut off of your headlights shouldn't be higher than a normal sedan's side mirror. Tested and proven na yan even the internationally known retrofitters like trs or lightwerkz ay ganito parin ang advise sa mga diy'ers na walang special equipments or walang basehan since dapat bago ginalaw ang headlight mo dapat minarkahan muna sa isang wall Ang stock cut off while yung car ay naka park on even surface.
    Sent from my CPH1809 using Tapatalk
    1. Casa?
    many headlights can be aligned, DIY. it's not difficult.
    the special instrument required is usually a long phillips screwdriver. lookit your car, po, and see how long it should be and how fat the shaft mustn't be.
    the most difficult part, is to find a suitable area... flat, preferably concrete surface, and a wall some meters away. google the aiming recommendations, po. i usually do my alignments in the workplace parking bldg, at night, when everyone has gone home. ilang beses nakong napag-kamalang may sira kotse...
    but if you prefer others to do the aiming, i am sure they will be happy to be of service. your retrofitters should do it as part of the service.
Looking for Projector Headlight Aiming Or Alignment Expert?
