Results 1 to 10 of 107
    Nov 2011
    I can vouch for Pegasus LEDs (fogs H8/H11 30W)
    Not blinding and same light distribution with OEM halogen bulbs.
    2k pair with shipping. Much better than Keon Sondra na lagi ni vouch. Nakaksilaw naman and 3x pricier.
    And endorsed by James Deakin.
    Mar 2018
    Quote Originally Posted by TheUninvited View Post
    I've seen a lot of cars installed with the KS led bulbs. They are bright and blinding at times.
    "Active" led bulb ba yun pegasus mo sir?
    Aug 2019
    Hi guys ask ko lang kung ok yung brand na osram na led headlight? Or mas ok ang hid, vios g variant pala gamit ko naka projector lens na sya or yung brand na keon sondra, diko kasi alam anu pipiliin ko tia
    Nov 2011
    What do you mean active?
    If you meant cooling, it's active cooling with fan kase. Passive means heat sink only. No?
    Mar 2018
    The one with the built in fan po.
    Jun 2013
    I bought a pair of Philips Ultinon Essential H7 for my car with a reflector housing. Ordered it via shopee. It only cost me 3k. It came from China. I believe this is an entry level LED. Been using it for 3 weeks already.
    My observations are:
    1. The cut-off is correct. No glare for incoming traffic.
    2. It is definitely brighter than the standard halogen bulbs. But its not extremely bright. Maybe next time I’ll upgrade to the higher end model.
    3. The light gives off that OEM LED look from a distance when you look at it, similar to the Civic or Rush.
    4. An adapter is needed because of the headlight housing design. Not the fault of the bulb. As a temporary fix, I used some Gorilla duct tape to hold it in place for now.
    after getting the nightbreaker laser next gens..
    im thinking of getting these lol
    GTR Lighting CSP Mini LED Headlights, 95 / 9145 Bulbs - GTR Lighting
LED headlight brand / suppliers
