Results 1,931 to 1,940 of 2382
- Dec 2002
- 2,335
September 5th, 2013 03:39 PM #1931cadash: welcome. thanks din. post ka naman output pictures and front shot of your car.
- May 2011
- 70
September 5th, 2013 04:01 PM #1932Sir question lang po. Gusto ko magpa install sa avanza 2013. I'm a bit worried sa halogen kasi pag madami sakay sa likod parang tumataas yung aim ng ilaw dahil mabigat sa likod. If ever magpa projector ako hindi ba nakaka silaw siya sa kasalubong kung madami din sakay?
- Apr 2008
- 63
September 5th, 2013 05:15 PM #1933*Sir garyq Sir do you give an option to put a 3000k for the foglights o 4300k rin just like the main HID headlights? Thanks sir!
- Dec 2002
- 2,335
September 5th, 2013 07:35 PM #1934spyler: yes kasi sa halogen hindi clear masyado yung cutoff ng ilaw. Sa retrofit mas clear and you keep your stock up/down adjustment. We can also compensate sa adjustment kung meron kang karga lagi sa likod.
maharot: stick with 4300k para match sa HL mo. sabay na natin fog retrofit mo
- Jul 2013
- 32
September 5th, 2013 08:35 PM #1935
- Apr 2008
- 63
September 5th, 2013 08:59 PM #1936hindi ko parin nacoconvince si misis sa fogs sir hahaha.di ko rin magamit credit card sir para sana tru paypal nalang ung fogs
payment in terms ko nalang sayo sir fogs hahahah j/k excited na ako with my projectors.hindi narin ako mahihirapan sa commonwealth hehehe
- Sep 2013
- 1
September 7th, 2013 12:02 AM #1938
Hi Gary,
I just read your Stage 1,2,3 definition in your website, I just realized that Stage 3 might not be necessary for my ride.
Here's why:
- My headlight has separate HI (halogen) and LO (H11 bulb in halogen projector and I already replaced the halogen bulb with HID).
- Cutoff and light focus looks fine to me. Although I would prefer more lighting power on my LO.
- The DRL is purely for aesthetics purposes.
So, would like to clarify with you, do I still need Stage 3 or Stage 1 is enough?
And how much difference in lighting power will there be before and after the retrofit (for both Stage 1 and Stage 3)? My reason for retrofit is to improve lighting power.
Also, saw your retrofit gallery and am a bit confused between Stage 2 and Stage 3 in your previous projects. Can you simplify the difference between Stage 1,2,3? I read your definitions in your website, but the pictures confused me a bit.
Thanks.Last edited by ano727; September 7th, 2013 at 12:06 AM.
- Dec 2002
- 2,335
September 7th, 2013 12:50 AM #1939On a basic H4 vehicle, difference with stage 2 and 3 is just the bulbs. OEM Philips ang stage3 and aftermarket ang stage2. I only use the very best aftermarket bulbs with less than 2% return rate in 4 years! Sa oem na Philips, wala pa or zero ang napalitan ko in 4 years, going 5. Sa output, around 15-20% ang difference, mas matingkad Philips and in the long run the Philips will give you the same output over a period of time. Sa itsura walang difference sayo kasi we will use the same bezel. The HID projectors will at least double your light output since halogen projectors ka.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
