Results 221 to 230 of 2382
- Dec 2002
- 2,335
September 20th, 2010 09:38 PM #222teamnitro: technically pwede ang retrofit sa kahit anong vehicle basta clear lens yung headlight. Hindi pwede pag fluted or may lines yung lens nung headlight.
jopsiawe: pwedeng pwede sa avanza
- Sep 2010
- 4
September 20th, 2010 10:08 PM #223may black projector headlights with angel eyes ba para sa honda civic 2010? how much po? salamat.
September 21st, 2010 12:19 AM #224
How much will it cost to retrofit the headlights of my 2002 Honda Civic Lxi. Please PM me the estimate and/or options available. Thank you.
- Jan 2009
- 62
- Jun 2006
- 53
September 22nd, 2010 10:27 AM #226sir,magkano po sa honda vtis 04' model,headlite assembly tapos hid bulbs.ang set up po ay yong stock na low na ilaw lang papa retrofit/hid with hi/lo beam then yong stock na hi beam ko is yon pa rin ang magiging pang flash/pass lite ko.pwede po kaya yon?pm na lang po or dito sa e-mail ko.xrm_explore *y.c.
thanks!!!
- Dec 2002
- 2,335
September 23rd, 2010 03:23 PM #227obsessed/jops/nplazaro: you got PM guys. email me info*gpglobalph.com or 9178554454
- Dec 2002
- 2,335
September 27th, 2010 02:42 PM #228HID Projector Retrofit for Everest 2010
Details:
FX bixenon
Philips 85122+ 4300k, 3200 lumen bulbs
55 watts ballasts (internals of these ballasts are the same as my Matsushita Ballasts)
Cayenne Apollo shroud
Custom Fog light retrofit
65mm sealed projector
D2S bulb
Matsushita ballasts
the everest had plug and play hid on both main hl and fogs which of course had terrible output as glare was all over the place and not so much light on the road. It was a popular brand installed with more than 1 year warranty but one bulb in the fogs exploded and burst in one year (hid bulbs are highly pressurized) and the ballasts were just wire-tired and dangling.
ballasts were now bolted on to the body
supply direct from the battery, 4 fuses and 4 relays. 2 on each side, oem style and the relay sockets are ceramic.
apollo/cayenne shroud
output, fogs only:
fogs and main hl, both bulbs 4300k
left output is limited by a car parked but the output is wide and intense
Please see first page for pricing. Retrofit for main headlamps or fog lamps. Cheaper if bought as a package.
sms 9178554454, info*gpglobalph.com
- Dec 2002
- 2,335
September 27th, 2010 02:43 PM #229stock
ballasts were now bolted on to the body:
- Sep 2010
- 92
September 28th, 2010 07:46 AM #230sir garyq, im using global dmax..nkprojector na xa.what improvements pa pwd gwin sa headlights ko pati fogs.nkHID na projector ko but d ako mxado satisfied.and want ko din sna HID fogs ko..what can u suggest me to do with it? pa-pm nmn po..tnx!
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
