Results 1 to 6 of 6
May 3rd, 2011 04:16 PM #1
guys kakapalit ko lang nang HID madalas masira yung kanan passenger side.. pero yung kaliwa wala naman prob.. ano kaya ang nagiging pro nito..
may nagsabe sakin na friend na baka kulang daw sa ground kasi naka tap lang ito sa tabi nang radiator...
May 3rd, 2011 05:38 PM #2
Possibly the wirings? Have the wirings going to the passenger side lamp checked thoroughly. Or yeah, maybe the grounding.
May 3rd, 2011 09:30 PM #3
are you using a wiring harness or just the stock headlight wiring? pls do note that the starting current of hid ballast can be as high a 15amps and can fry your stock wirings. I'm assuming the bulbs are the one being busted. try to isolate the problem by exchanging the ballast to the other side.
May 4th, 2011 12:58 PM #4
May 4th, 2011 08:26 PM #5
I suggest you install a wiring harness to protect your stock wiring. although power consumption of hid is generally lower than halogen bulbs, the starting current is very high.
your ballast on the passenger side might not be getting enough power. note that wire going to this side is longer than the driver's side.
May 7th, 2011 02:03 AM #6
high idle RPM at engine start
