Anyone of you guys know where can I buy the cables from ballast to the bulbs? meron ako nung balalst at bulbs pero di ko makita yung cable (High Voltage) niya.Originally Posted by Ungas
You might want to try Jetcar along Banawe between M Cuenco and Dapitan, they sell HID kits.
Newer ballasts nowadays come out with the high tension wires attached to the internal parts of the ballasts.
i also sell the same as what ungas is using with 1 year warranty pa distributor lang ako sa phils. kaya no need to ship back and forth...
less than what you will incur if you buy from abroad. direct kasi. Ungas is right hi-low beam is just used for passing throughj or overtaking it is not meant for Hi beam penetration, mag aad lang ito ng light for you to read yung mga signs...
