Results 1 to 13 of 13
    nag-o-off din bigla HU ko tapos pag bitaw ko sa preno, on sya ulit! alternator problem kaya ito? need your help and input!
    tnx!
    malamang alternator...have the same problem pero d ganyan kalala...nagdidim pero subtle lang
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jan 1970
    tsk..tskk ssaloon.. sa akin hindi off, pag above 25 na yung volume ng HU max ko is 30, sumasabay sa bass ang light ng HU.. binibiro tuloy ako na yung HU ko hiphop he..he.he. pero pag low volume naman okay lang.. related din ba ito sa problem ni ssaloon... tnx.
    you can bring your car to any motolite battery center so that you can have your electricals checked.
    have them check the charging capacity of your alternator.
    a standard rule is that: with the engine running and with all accessories on, the voltage output of your alt should be at least 13volts.
    hth.you can bring your car to any motolite battery center so that you can have your electricals checked.
    hth.
    tnx dude!
    will bring my car to my suking battery dealer to have it checked out :mrgreen:
    marwen::: ganon tlga yan pag upgraded sounds tapos stock electricals... baka kelangan mo ng capacitor... nagdidim din yung mga courtesy lamps ko pag malakas na patugtog ng radio ko eh :mrgreen:
    baka sa batery clamps.. ganun nagyari sakin dati ehh.. sabay sabay lhat ng ilaw.. prng disco kng magblink :mrgreen:
    baka grounded lang.
    sir, ano po yung grounded?
    Jan 1970
    si otep yun grounded bwa..ha.ha..ha...
    <b>ssaloon</b>
    baka kulang sa ground ang ibig nyang sabihin..
    Quote Originally Posted by marwen
    <b>ssaloon</b>
    hahaha
    what i meant was you check your wirings baka yung power supply ng brake lights mo grounded dun sa power supply ng sound system mo.
    how did you wire your sound system? is it directly connected to the battery or sa car accessory wirings. how do you power your speakers? through an amp or through your head unit?
    recta sa batt and internal HU amp.
    so you dont have an external. pa check mo wiring mo. am sure it's grounded.
headlights dim when i step on the brakes...
