Results 341 to 350 of 361
- Dec 2002
- 2,335
August 10th, 2014 11:35 PM #341oliver: you either change the bulb or the ballasts. Nothing to do with the AFS. Pls see www,hidretrofit.net. That's a simple fix
August 11th, 2014 11:17 PM #343
Thanks garyq, check ko..
Shok, first batch ako ng mga lancer mx noong unang panahon, 2.0 pa mga makina at CBU from japan...busog pa ang mga MX noon.
August 11th, 2014 11:26 PM #344
Boss gary, meron bang stock bulbs? Parang upgrades yung mga nakita ko..i just want to stay stock sana...
August 12th, 2014 12:09 AM #345
Boss, normal ba sa self-levelling HID headlamps ang medyo nagfi flicker ng itsy bitsy tiny bit kapag nalulubak?
I've read kasi online dahil daw yun kasi suspended yung projectors kaya gumagalaw kapag nalulubak.
Is this a normal thing or I should talk to my dealer?
- Dec 2002
- 2,335
August 12th, 2014 01:14 AM #346oliver: meron stock d2s
great: it can move a little bit either meron self levelling or wala
August 12th, 2014 12:05 PM #347
August 12th, 2014 12:14 PM #348
Beam shaking or flicker patay sindi ng mabilis?
Kung beam shaking, mukhang normal, pero kung patay sindi ang ibig mong sabihin ng flicker, patingnan mo na sa dealer.
Yung auto-leveling naman may motor lang na nakakabit sa up down adjustment screw diba? same mounting points and adjustment method sa mga walang leveling motor.
Continuous self leveling ba ang sa Kia? Meaning nagseself level sya habang nagdridrive ka?
Sa Corolla kasi, mag self level sya as soon as nag-on ka ng headlight depending on vehicle load. Then fixed na sya right after. Di ko napapansin na nagcontinuous self leveling sya. Parang magwear out agad yung adjustment nut sa loob ng headlight kung ganun.
August 14th, 2014 12:39 AM #349
I believe self-levelling only acts upon startup when it detects a heavier load on the back, the headlights will point a bit downwards just to compensate for the sagging behind.
I will report it to the dealer because mine is like flickering in a sense a medyo kumukurap yung HIDs.
August 14th, 2014 11:10 AM #350
Guys, yung hid ko pag matagal ng naka bukas biglang di na gagana yung high beam. Ano kayang cause nun? Thanks in advance po.
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
