available yan sa accessories shop just ask for them bosch ceramic sockets parang 250 each ata e
*Sir Ungas
ano brand pag nakalagay sa base is H4 130/90w.......
blue color un bulb? thanks......
*dieselNUBI
yan gamit ko.............
Mga sir,
If i paln to change my bulbs sa headlight ng higher watts do i need to replace the socket of the bulb un kinakabitan ng wires? may biyak na rin kc un orig ko so i plan to get a replacement saan ba nakakabili nito?
Most medium to large electrical shops have them... Reys electrical sells them at P250 a pop.
saan po ba nakakabili ng Heavy Duty Ceramic Socket? I experienced burning both my dim light sockets eh while using 100W bulbs...now I'm using a Koito Whitebeam Ver. II 55W... which is not really white but yellowish white....
hmm..i had to revive this thread...coz im going to change bulbs sa isang car namin...although kahit stock bulbs lang ang plan ko (visionplus sana, kaso mahal baka mag-narva na lang ako na 60/55w, ok kaya yun?) nung nagtanong ako sa tower of david sa espaņa how much for the labor of changing the headlights sbi niya 80php lang daw so ok na..then suggest niya why not change to a higher wattage bulb kung nahihinaan ako sa stock..and sabi niya and i quote, "di na naman kailangan palitan yung sockets eh (i mentioned kasi about changing into ceramics), kaya na daw ng stock sockets yun and a good relay" is there any truth in this?
80 bucks to change headlamps??
ang mahal naman non.
ang alam ko pag bumili ka ng bulb e libre na kabit.
hindi lahat eh kaya yan.pali9bhasa hindi siya ang ma hahassle pag natunaw ang socket mo.at siguro wala sila nung ceramic,.tsssss...Originally Posted by zechs
you can GAMBLE not to change your sockets and add relays and upgrade wires.pero i personally WOULDN'T GAMBLE.electronics yan...delikado talaga.better be safe than sorry.mas magastos pa pag nasira mga gamit mo,.
yeah..hindi lahat kaya..pero alam ko sa shop ni sir glenn...kaya...hehe :D pa-pm naman sir glenn kung may narva kayo 60/55w. di ko kasi alam kung orig yung nasa handyman eh..hehehe or what kind that is..(costs around 150php ata).
mahina ba ang labas na ilaw kapag gumamit ako ng 100/90w na bulb sa headlight na ang original na bulb ay 60/55w lang?
mas lalakas and mas mas mainit. palitan mo socket mo to ceramic.Originally Posted by jeff
Signature
thanks! magkano ba yung ceramic bulb socket and kailangan pa ba mag pa upgrade ng wirings at magpakabit ng relay kung gagamit ng 100/90w na bulbs?
what's the brightest (huwag lang yung masyadong mahal) All Weather Bulb na meron ngayon? ano yung brand at saan available? busted na kasi yung low beam ng bulb namin kaya kailangan na magpalit. currently using Bosch 110/140w at upgraded narin wirings at socket namin. gusto ko sana mas mataas pa yung output wattage pero yung consumption nya nasa 90/100w lang.
Guys is it possible to change the type of bulb you have sa car. Kasi yung fog lamp ng Optra yung H24 ata na bulb.?? First time ko lang narinig to eh. Is it possible to change it to something like H11 or H1 or H7? Thank you!
you can also try using super yellow na color. i've used the super white, super plasma from PIAA and raybrig. the super yellow is the most effective bulb i've used. i used it on my jazz for both H4 and H11 bulbs. i was so impressed i replaced my super white raybrig bulbs (h4&h3) on my revo kahit di pa busted.
Sir napapalitan po ba yung mga type of bulb na stock? Kasi sa Optra po pahirapan yung fogs ibang klase yun bulb walang available na HID for fogs ng Optra. Can this be changed to an H11 socket or something similar? Thank you
