Results 21 to 40 of 57
    #21
    ano mas maliwanag? vision plus or all weather? i like the stock color.
    Sep 2002
    #22
    coincidentally, i was just reading through this article on bulbs.
    http://www.autoexpress.co.uk/?produc...y.php?id=39920
    #23
    bluish white light gets absorbed by rain. Better to use bulbs with some yellow... standard halogen bulbs do. Its probably cheaper just to upgrade to OSRAM 100 or 120 watt bulbs and ceramic sockets than buying those expensive blue, rainbow, ultra-white bulbs.
    #24
    all weather and vision+ are yellow =)
    if i changed to osram 100w or 120w plus the ceramic sockets, wont the lens melt or form bubbles from heat?
    #25
    make sure your lens are made of glass & plastic.
    #26
    fellow crosswind users,
    pwede ba higher wattages sa crosswind?
    may nakita ako before naka HID black xwind.
    #27
    HID bulbs only consume 35Watts. It is lower than your average halogen bulbs. But mind you, those HID bulbs do get hot same as with halogens.
    #28
    How yellow are the Philips all weather bulbs? Hindi ba mix ng blue, yellow and white yung all weather?
    #29
    All weather hence its name, project yellowish hue overband. To be able to use on foggy and or rainy weather.
    Yung gusto mong mix ng blue, yellow an white is called rainbow bulbs. Dati may lumabas na bulbs. But as far as I could remember, there used to be a plastic that is in place before the halogen bulb to change its colors.
    Jul 2003
    #30
    where do you buy this bulbs?
    - philips
    - osram
    How much?
    #31
    Auto supply shops and car accessories shop sometimes carry these brands.
  12. jondy is offline Tsikot Mindanao Chapter Moderator
    Join Date
    Jul 2003
    #32
    dieselNUBI,
    meron kmi xwind. nilagyan ko ng all weather bulbs. 130/100 watts. ok nmn sya maliwanag. gs2 ko nga lagyan din yung fog lamps nya, pwde kaya yun?
    #33
    jondy::: All-weather, blue-vision and etc. bulbs are only 55/60W bulbs. The package may indicate 130/100, 135/110 and etc for marketing reasons. You should be able to check the actual wattage of your bulbs at the base stamped and voltage use.
    Aux driving lamps can also be changed, provided that there is an aftermarket bulb that can fit in. Most common bulbs used are either H1 or H3 types.
    #34
    so any other xwind users out there that had upgraded their headbulbs?
    im currently using visionplus... but im not yet quite satisfied bcoz i have tints on my windshield and i want a much more brighter headlights... no white headlights...
    maybe 120w will do the trick.
    #35
    gamit ko sa hilux s ung Catz 85/80 i thnk pero sa case nya indicates output of 170/160 na parang marketing reasons lng ata.
    but to compare it with philips/osram na gamit ko nuon malaki din ang difference. medyo pricey nga lang ung catz
    imo stay away from taiwan bulbs. gamit ko before were those pure whites na before ng 1 year isa ay busted the other nabasag. i had to clean the headlight casing pa.
    Oct 2003
    #36
    Hey,
    may I ask something? Did you changed your "Headlamp" wiring harness? or wiring system?
    Coz a co-employee of mine who changed his Nissan Sentra's headlamp experienced his "HEADLAMP Socket" being burned out. Malakas at mainit daw, hindi kaya ng Sentra. The default socket wattage is 55 watts.
    Dapat daw palitan ang wiring harness....so did you?
    Jan 2003
    #37
    what are the advantages of having a blue/white colored bulb over an all weather bulb?
    Jul 2003
    #38
    parang sakin ang ganda ng blue/white color bulbs tlagang malinawag. pero parang ang init... d ko lam un stock headlights ng rav eh pero gusto ko sya lagyan ng blue/white if hindi sana kamahalan...
    #39
    Originally posted by Paulo
    Hey,
    Nissan OEM sockets burn out easily when you upgrade to higher wattage bulbs and relays... Change to Bosch ceramic sockets, ayus na yan.
    Oct 2003
    #40
    Sorry for asking but where do you buy those cermic sockets? and up to how many wattage is this?
healdlight bulbs
