Results 1 to 18 of 18
    mga repapips,
    ask ko lang, effective ba itong mga headlight booster kits? saw one in blade shop last friday. kaso H4 sya, i'm using HB4 9006-9005 lamps.
    right now, i'm using narva 9006 70w for low beam, and super white blue caps 9005 80w for high beam.
    salamat sa mga opinions, comments, suggestions, recommendations nyo.
    Jul 2006
    magkano chief price nyan?
    di ko tanda, pero less than 1K.
    Feb 2007
    Yung ganyan sa blade mga 400-500 yan. Nakita ko na rin yan, pero di ko pa na-try. Ideal daw to sa mga gusto mag upgrade ng headlights. May Narva din na ganyan mga 800-1k.
    That's the exact one that I have on mine
    Paired it with a Wurth Super White bulb, lakas talaga compared sa stock. I bought my wiring kit for about P700, forgot how much the bulbs are.
    Very effective!
    Aug 2005
    Medyo misleading for me. For me hindi talaga iyan headlight booster per se. Kundi it's an upgrade to your headlight wiring harness so that you can use higher power headlight bulbs.
    Ceramic bulb socket, higher gage wires, higher current capacity relays.
    Di ba dapat pati ang wiring from the battery (or is it alternator) ay upgraded din.
    Apr 2006
    try mo ganito na lang katulad sa akin: relays (30amp bosch) + 15A fuses + thicker wires + ceramic sockets on osram 80/85 hyper all-season h4. super liwanag.
    i'm not very comfortable with the subzero brand. yung narva na lang kunin mo kung headlight booster.
    Jul 2006
    Exactly, it's just an upgraded kit for the wiring harness and sockets, nothing more.
    i agree with you bro... its not a booster per se, but components that you need to upgrade your HL.
    Aug 2006
    I'll be more worried with my headlight dome, nowadays headlights are hard plastic and not glass. Been seeing new cars with tarnish headlights during morning could be the effect of too much power.
    I've also seen a VIOS in the dealership with burned down wirings due to headlight conversion.
    Aug 2006
    ginagamit lang yan for cars manufactured 1995 and below kasi ung ngaun especially mga cars manufactured 2000 above can accomodate ung mga h4 na superwhite bulbs because ung mga stock is only 60/80W ung mga bago it 90/100 w i use white bulbs in my three cars and no problem with the wirings so far
    may tanong lang ako mga sir kasi nung pinagawa ko car ko pati wirings pinagawa ko na rin, balak ko kasi maglagay ng 90/100watts na narva lamps sa car ko kasi parang mahina pa rin para sakin yung standard na 55/60watts na ilaw ko, may relay kasi na nakakabit sa gilid ng engine bay ko bosch yung tatak paano ko malalaman kung yun yung relay ko para sa HL ko, kung yun yung HL relays ko paano ko malalaman kung kaya nya yung 90/100watts na bulb at ano dapat nakatatak sa relay para malaman mo na pwede syang pang 90/100watts na lamps?
    Sep 2006
    pasingit lang po, kailang ba ng relay kung nagpalit ng lamp to 100/90w Koito H4 gamit ko.. ang stock is 60/55w koito.. naka ceramic socket lang ako.. at magkano ba yang relay? dalawa daw kasi ang kailangan..
    saka paano kung may relay na ako kahit hindi ko na ba palitan yung h4 sockets na hard plastic?
    Quote Originally Posted by tibo_3rd View Post
    parang relay kit lang yan dba? at pinakapal lang ata yung wire harness nya.. siguradong lalakas yung ilaw mo..
    bawat isang headlight mo may sariling relay, and higher wattage na wiring harness para makayanan yun mga 100W na bulb. palit ka na rin ng ceramic socket kugn di pa yata kasama. plastic pa yata yun kasama nyan.
    its just a wiring upgrade so that you can use higher wattage bulb. thick wires and relay. you can fab your own.
