Results 11 to 18 of 18
December 18th, 2007 06:14 PM #11
I'll be more worried with my headlight dome, nowadays headlights are hard plastic and not glass. Been seeing new cars with tarnish headlights during morning could be the effect of too much power.
I've also seen a VIOS in the dealership with burned down wirings due to headlight conversion.
December 18th, 2007 07:57 PM #12
ginagamit lang yan for cars manufactured 1995 and below kasi ung ngaun especially mga cars manufactured 2000 above can accomodate ung mga h4 na superwhite bulbs because ung mga stock is only 60/80W ung mga bago it 90/100 w i use white bulbs in my three cars and no problem with the wirings so far
December 18th, 2007 08:42 PM #13
may tanong lang ako mga sir kasi nung pinagawa ko car ko pati wirings pinagawa ko na rin, balak ko kasi maglagay ng 90/100watts na narva lamps sa car ko kasi parang mahina pa rin para sakin yung standard na 55/60watts na ilaw ko, may relay kasi na nakakabit sa gilid ng engine bay ko bosch yung tatak paano ko malalaman kung yun yung relay ko para sa HL ko, kung yun yung HL relays ko paano ko malalaman kung kaya nya yung 90/100watts na bulb at ano dapat nakatatak sa relay para malaman mo na pwede syang pang 90/100watts na lamps?
- Sep 2006
- 51
December 18th, 2007 08:48 PM #14pasingit lang po, kailang ba ng relay kung nagpalit ng lamp to 100/90w Koito H4 gamit ko.. ang stock is 60/55w koito.. naka ceramic socket lang ako.. at magkano ba yang relay? dalawa daw kasi ang kailangan..
December 18th, 2007 08:52 PM #15
saka paano kung may relay na ako kahit hindi ko na ba palitan yung h4 sockets na hard plastic?
December 18th, 2007 10:52 PM #16
December 19th, 2007 12:58 AM #17
bawat isang headlight mo may sariling relay, and higher wattage na wiring harness para makayanan yun mga 100W na bulb. palit ka na rin ng ceramic socket kugn di pa yata kasama. plastic pa yata yun kasama nyan.
December 19th, 2007 02:30 AM #18
its just a wiring upgrade so that you can use higher wattage bulb. thick wires and relay. you can fab your own.
Xiaomi E-Car
