ayaw gumana ng hazard lights ko pero weird once you push it hard iilaw yung left signal lights ko steady sya...pag bitaw wala na ulit what might be the problem???![]()
Yung signal lights gumagana?
if gumagana yung lights, then next thing to check is the hazard switch. baka may loose connection lang.
If the signal lights work, then your flasher relay and signal light switch are ok.
You can narrow it down to the switch and wiring specific to the hazard switch.
Uy salamat sa tulong nyo!tama ok ang mga relays nag ka problem mismo sa switch pinarepair ko na sa banawe kaso 300 dun sa mga tambay dun
