Results 1 to 7 of 7
- Mar 2004
- 74
November 16th, 2006 03:22 AM #1ayaw gumana ng hazard lights ko pero weird once you push it hard iilaw yung left signal lights ko steady sya...pag bitaw wala na ulit what might be the problem???
November 16th, 2006 10:14 AM #2
November 16th, 2006 10:24 AM #3
Yung signal lights gumagana?
November 16th, 2006 01:04 PM #5
if gumagana yung lights, then next thing to check is the hazard switch. baka may loose connection lang.
November 16th, 2006 03:12 PM #6
If the signal lights work, then your flasher relay and signal light switch are ok.
You can narrow it down to the switch and wiring specific to the hazard switch.
- Mar 2004
- 74
November 19th, 2006 08:42 PM #7Uy salamat sa tulong nyo! tama ok ang mga relays nag ka problem mismo sa switch pinarepair ko na sa banawe kaso 300 dun sa mga tambay dun
Monk-owned R53
