Results 1 to 6 of 6
- Nov 2007
- 6
November 12th, 2007 04:55 AM #1Grille problem....
Ok pa naman yung grille ko, may konting biyak at medjo lumubog na (nabangga kasi), pati yung headlights mejo lumubog na din. Wala pa sa align yung mga signal lights.
Bottomline po, kung pwede pang ayusin, saan ko po pwede dalhin? Yung highly recommended pero reasonable naman po yung price. At kung kelangan nang palitan, saan po pwede bumili? Mejo tight po yung budget.
Hindi po sporty, basta nice and clean lang po.
BANNED BANNED BANNED
- 3,790
November 12th, 2007 05:19 AM #2sa latero mo ipatingin...pero most of the time DIY lang yan. kung nagkahistory ka ng banga...baka na dent din ang bracket niyan...so the latero is best option.
kung walang tama ang bracket... then replacing the grille will be your option...kaso walang murang grille...kahit sa surplus shop, I doubt if you can get one na less than P1000.
Kung talagang nagtitipid ka, bili ka na lang muna ng epoxy glue at i-glue mo back to shape na lang yang grille mo. You will have to remove it from the car and make a temporary bracket to straigthen it, bago mo i-epoxy.
- Nov 2007
- 6
November 12th, 2007 05:32 AM #3Thanks wildthing
Di naman ako ganon ka-tight yung budget (epoxy... hehe!). Alin yung bracket (noob po)? yun ba yung nagyayakap dun sa grille at headlights? Kung iyun e ok pa naman sya kaso nagtataka lang ako kung baket lumubog. Di ba yung normal na headlights e aligned sya dun sa edge ng hood kaso lumubog sya ng 1 inch e. Kaya tuloy mukha syang singkit.
I'll follow your advise, punta muna ako sa friendly neighborhood latero ko para mapa-ayos.
Thanks wildthing!
November 12th, 2007 10:17 AM #4
Tama si Wildthing. DIY lang yan. Give us a picture of the grill and lamps and sabihin namin kung saan ang mga screws. Bent or collapsed brackets lang yan. Most of the front end are designed that way to obsorb impact.
November 15th, 2007 12:25 PM #5
i agree. . .maybe you can find the problem and fix it yourself. . .merong positioning pin (ba tawag dun?
) yung headlight and signal light, baka nabali na so lumihis na. . .in that case, kailangan ngang gumamit ng super glue kung andun pa yung pin, which is made of plastic. . .kung wala na, you can improvise, or buy a new headlight and signal light. . .
- Nov 2007
- 6
November 17th, 2007 02:11 AM #6Sorry mejo busy sa work kaya na late tong response ko. I'll post a picture mamaya pag mejo maliwanag na.
got to check one out at sm san fernando today. rear visibility is very poor :twak2: and as typical...
2020 Kia Sonet
