Results 1 to 10 of 25
- 342
December 6th, 2002 11:41 PM #1diesel peeps, ano kaya problema dito kc kakapalit k lang ng headlights bk may wire na dumikit kaya laging pundido ang fuse ng headlight tama ba ako? :roll: ang ginawa kumuha ako ng wire binalot k yung fuse umilaw, may masisira ba dito? temporary lang naman ito fot themean time para may amagamit ako sa gabi.
December 6th, 2002 11:55 PM #2
Tama. Mismo . Also look for loose wiring o baka naman maliit ang amp rating ng fuse mo.
- 342
December 7th, 2002 12:01 AM #3sir afrasay,
original po ang fuse na nasira di ko lang alam kc tumaas ang wattage ng headlight ko compare sa luma kong headluight di kaya ito ang reason kung bakit dapt mag palait ako ng fuse na mataas ang amp?
December 7th, 2002 12:05 AM #4
nakaw!!!
nagpalit ka ng higher wattage bulbs nang hindi nag uupgrade ng wires!?!?!?
upgrade ka ng wires chong.....masama yan...
- 342
December 7th, 2002 12:07 AM #5sir glenn10, pinakabit ko kay ronald ang new headlight ko 100watts daw yun pero wala naman pinalit na fuse or wire:roll:
December 7th, 2002 12:10 AM #7Originally Posted by 4x4fan
sabihin mo sabi ko :wink:
mura lang naman ang wiring harness eh....
complete pa.....fuse...relays...etc...japan wires....
dika magsisisi.
- 342
BANNED BANNED BANNED
- 3,790
December 7th, 2002 06:36 AM #9Sir Glenn,
Ung wire harness nyo ba ay meron ng ceramic (bosch ba yun?) na bulb socket na kasama? I planning to upgrade my headlight din... e di ko na matrace sa old kotse board yung post on thie ceramic bulb socket being sold somewhere in manila....
Dati kasi nung nagwire upgrade ako (old service pickup ko) ang nasunod (o natunaw) ay iyung bulb socket na. Wire and fuse no problem.
December 8th, 2002 12:56 AM #10
Saan ba nakakabili ng ceramic sockets? Yan din ang problem ko yun sockets. 90/100w ang bulb ko.
high idle RPM at engine start
