Results 1 to 7 of 7
- Dec 2012
- 36
September 20th, 2013 08:11 PM #1Magandang gabi mga masters. I'm having trouble installing hidbulb on my Mitsubishi Pajero FM's projector foglamps..
Di kasya yung cover nung nakasalpak na yung bulb sa housing.. masyado pala matangkad hid bulb compared sa halogen bulb..
Ano kaya magandang gawin doon sa cover or may mabibili kayang compatible covers na matambok? Don't worry may cutoff po yan kasi projected yung lens, may fixed flaps sa ilalim nung lens.. Maraming salamat po sa mga makakatulong sa aking napakabigat na pinagdaraanan..
Last edited by Zeachrone; September 20th, 2013 at 08:11 PM. Reason: Wrong Spelling
September 20th, 2013 09:07 PM #2
Bubutasin mo then reseal it using elastoseal/vulcaseal
Parang sa SiR fogs
September 20th, 2013 10:57 PM #3
I've seen some retrofitters put a pvc pipe extensions on the back of the housing para ma extend. But that's for the headlight. I guess you can do the same for the fogs. Other options if you want to DIY is PM mo Redline autoworks baka meron silang morimoto matchbox or PM garyq so he can set you up with your fogs. But yung last two options medyo costly but sulit naman
- Dec 2002
- 2,335
September 21st, 2013 12:16 AM #4you are going to burn the chrome finish inside the fog lamp reflectors. also output will be mediocre, dapat nag stock halogen bulb ka na lang
- Dec 2012
- 36
September 21st, 2013 02:13 AM #5Laki po kasi ng improvement sa lighting sir eh.. up to 5x brighter compared dun sa halogen bulb na tinanggal ko,parang singlakas na nya yung NightBreaker na nakainstall sa headlight. Tsaka ganun ba talaga kainit sir para malusaw? Kasi 35w lang yang HID eh yung tinanggal kong halogen bulb 55w.. Thank you for the response..
September 21st, 2013 04:17 AM #6
I think what garyq meant is may discoloration na mang yayari sa chrome coatings nang reflector bowls especially pag yung mga cheap hid bulbs yung ginamit mo and pag wala na ang chrome reflectors mo, wala na ring silbi yung fogs mo. I don't think the he meant na ma lulusaw literally yung housing mo
you should listen to him though.
If you don't mind me asking, anong kelvin rating yung bulb mo na ginamit?
September 26th, 2013 01:05 AM #7
Fog lamp repairing is easy..
Cut pieces of shiny aluminum tape then place it inside.. Viola!! Good as new!!
The aluminum tapes aren't noticeable inside the fog lamp
Here's another one: And why I insist on going higher up on the allowable viscosity than what...
Mineral , semi synthetic or fully synthetic?
