How to do double contact signal light? Both nakailaw front singnal lights mo? pwede po bai-DiY yan?? tnX
pwede po why not. that would require you to buy 2 double contact sockets for the front ad 2 for the back and ganun din you have to buy 2 double contact bulbs for the front and the back
then ireplace mo yung sockets sa original wiring na luma then may isa dun extra wire yan yung pang double contact i tap m,o sa positive ng parklight ganun lang. so pag naka park light ka iilaw na yung isang filament sa loob make sure yung mahinang filament ang iilaw then pag signal mo iilaw yung mas malakas na filament
there you have your diy double contacts. pag di niyo masyadio magets open up your brake lights sa likod double contact na yan follow it
Tnx sir xenoptics, pero noob talaga sa mga electricals, nagtanong ako malapit sa shop namin dito, P500 singin sa double contact, mura naba yun? Pagkano po ba aabutin ko pag DIY? tnX
My ride is Sentra B13 (LEC body) , naka double contact na ata siya?! Yung ba yung parang bombilya nya may dalawang kamay pero ndi pantay?
ser tanong ko lang po, nagpa double contact po ako, kaso alternate po ung ilaw nya pag nag signal or hazzard, pano po ba gagawin ko gus2 ko sana isabay nalang sila???
