Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    Jan 2004
    #21
    Quote Originally Posted by StraightSix
    For cars with plastic lenses, don't forget to consider the additional heat that will be generated by uprated bulbs.
    this is true. napansi ko nga nasira yung sa may lens ng civic namin. may parang sunog na part dun sa likod nang bulb.
    Aug 2004
    #22
    for cars with plastic lenses, safe na ba yung 90/100w bulb na upgrade? masisira pa kaya ang lense nito?
    #23
    the plastic lenses were designed by the engineers to handle the heat generated by stock bulbs (60W). you can put any bulb wattage, but it will deteriorate at a faster rate with higher than stock wattage bulbs. if the lenses were designed to last for 10 yrs with stock bulbs, it might only last 8 yrs for 80W bulbs, 5yrs for 100W bulbs, etc.
    Signature
    #24
    i just upgrade my H4 bulb from philips vision plus 55/65 to Osram 80/100 just last week on my revo..
    halos 2 years ko din gamit ko yung visionplus 55/65 and walang nagfla-flash sa akin kahit sedan type....
    pero ngayon meron ng mga ilang sedan type na nagfla-flash using the higher wattage bulbs.. siguro dahil sa additional glare na rin.. i have to adjust my headlight aim this weekend..
    Jun 2005
    #25
    Quote Originally Posted by ssaloon
    when i used higher wattage bulbs and had fatter wires and relays installed, yes parang nasisilawan mga incoming drivers. lagi nila ako finaflash dahil akala nila naka high beam ako
    You could use higher wattage (candle power) light, but you have to aim it properly. I use them on all my vehicle including my son's car and so far its been good, nobody flash me yet at ang liwanag ng kalye kapag gabi.
    Nov 2004
    #26
    my super whites sometimes dies on my altis lows. i think i need relays. can anyone explain to me what relays are for ?
    around how much would those cost?
    where could i buy them?
    thanks.
    #27
    it dies then switches back on when you flick the switch or patay lang talaga at kelangan na palitan?
    Nov 2004
    #28
    they go back when you flick the wires behind the bulb.
    anyway, had them changed this morning, but, now patay naman ung park light on that same side.
    higher wattage bulbs could burn your socket pala, nakita ko na natunaw na ung socket, sabi nga ng cousin ko kanina "buti nalang hindi pa natuluyan". so he changed them to a lower wattage whiteys.
    my only problem now is the parklight.
    Aug 2004
    #29
    Try upgrading your headlight harness by adding relays, thicker wires and ceramic sockets (won't melt). It's a good weekend DIY project. Buy lots of fuses though hehe. Relays go for 100 each. Ceramic sockets are around 150 each.
    Directions here: http://www.danielsternlighting.com/t...ys/relays.html
    Nov 2004
    #30
    where could i buy ceramic sockets?
    meron ba yun for the hb4 socket?
    i might change back to my higher wattage bulbs and put my low wattage whites on my sis' car, hahaha.
    sorry, dami questions. thanks.
    Aug 2004
    #31
    Got my ceramic H4 sockets from Nihhon Banawe. Don't know if they have HB4 sockets though.
Does Higher Wattage Bulbs Blind Incoming Traffic?
