Hi, this is quite a noob question, but anyway, our car has the auto headlight cut-off feature that when you forget to turn off the headlights, it beeps then the headlights go off after you remove the key and open the door. And when you turn the key to the "ON" position, the headlights turn back on since the headlight switch was left on.
Is it okay to utilize this "anti battery drain" feature as DRL?
Sent from my iPad using Tapatalk HD
