Results 1 to 10 of 10
February 26th, 2013 10:15 PM #1
I know they're turned on during the day,but r aren't they turned off at night?????
February 26th, 2013 10:29 PM #2
- Sep 2011
- 626
February 26th, 2013 10:34 PM #3I have mine turned on always at night haha.
Naka tap lang kasi sa park lights
February 26th, 2013 11:23 PM #4
Meron DRL na multi-function. It has its own controller.
1. Always on pag running ang makina. Patay sya pag patay ang engine
2. Sasabay sya sa signal lamps (if activated)
3. Pag nag turn on ang head lamp, mag dim sya (if activated)
Meron din DRL na wala ng ginawa kundi iilaw lang sya talaga.
February 26th, 2013 11:46 PM #5
Depends on the car's make and model, and if it's DIY, how it is configured (controller-based or otherwise).
Modern Honda OEM DRLs in US and Canada uses the hi-beam at reduced power. They're activated with the engine running and the shifter out of Park (for A/T). They're deactivated when you turn on the headlights.
February 27th, 2013 12:31 AM #6
- Dec 2002
- 2,335
February 27th, 2013 01:03 AM #7Each country will have its own regulation but for me daylight nga so sa ignition it should turn ON and OFF when you turn on your parklights. Ganyan sa Jazz ko. I think mas maganda naka OFF sa gabi since redundant na when you have park lights. Some will have it sa low intensity sa gabi which will look good on some cars. Basta hindi nakaka abala sa iba, ok naman I think.
- Jul 2008
- 479
March 4th, 2013 01:05 PM #8maayos ba yung mga binebenta sa Blade na tag 1k plus lang pero walang control module. direct tap ang +/- wires ng led sa wirings ng kotse. mabilis siguro ito mapundi dahil direct connection w/o the control module. tama ba?
- Sep 2011
- 626
March 4th, 2013 02:00 PM #9
- Feb 2010
- 55
November 12th, 2013 05:54 PM #10my civic FD has an OEM DRL. It automatically turns on 3-5 seconds after you release your handbreak and uses 50% (brightness) power of the high beam. It turns off automatically if:
1. headlight is turned on
2. shifter is either in P or N position and handbreak is engaged within 5 minutes
3. you turn off your engine
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
