hi mga sir currently naka hid ako and balak ko bumalik sa stock using osram all weather kailangan ko pa ba palitan yung sockets and magpa rewire?
yun bosch or osram all weather ba, direct drop in replacement sa civic (dimension)? sabi kasi nung kausap ko sa banawe, ipa all weather ko na daw. bumbilya lang daw papalitan oks na. hindi ne kelangan ng kit. im planning to change bulbs kasi madilaw na sya. kung papalitan ko nito, worry ko baka sabog ang buga ng ilaw.
dati narva all weather ako... okey kahit sa baguio at halos 5 yrs ang itinagal
bosch ang ipinalalit ko na all weather after mapundi yung isa dahil wala akong mahanap na narva rin... malabo sa gabi lalung lalo na pag umuulan
ngayon osram all season ang ipinalit ko... parang narva din ang buga niya mas okey kesa bosch
Hi all,
I currently have both BOSCH all weather H7 85W and OSRAM H7 55W all weather installed on my santa fe. The OSRAM's light is yellowish white but mas malakas sa stock 55W ko and is being used as a primary low beam (better results in rain) on projector type lens. The BOSCH naman is yellow (parang H4 bulb na may yellow glass cap) but since its 85W and is used for high-beam it does its job well lighting up farther and wider than the stock. The BOSCH sold for P750 but the guy said its made in korea, unlike OSRAM daw germany... I have been using it for a month so far ok naman. I had H4 100/90W FLOSSER golds before and it had yellow purple light paired with clear 100w H1's on hi-beams awsome...
do you need to install relay when upgrading to all weather bulbs coming from stock?
does the stock bulbs have relay?
ako i like to buy a philips XV (priority) ot s Osram NB+, kaso dami daw fake nito![]()
Kahit naman PXV madaming fake. You just have to check the quality parin to be sure. I bought ONB+ so far ok naman. Mas maliwanag talaga compared to stock.
We have genuine Philips XV and OSRAM NB+.
Yun nga lang sa Cavite ang shop namin but we can meet you at MOA or Petron Macapagal pag meron lalakad sa amin pa Manila. We can also ship to you via LBC kung nasa ibang cites outside metro kayo. Kayo magbabayad ng pa-LBC.
For XV we have H4, H7, H11 in stock. HB3 and HB4 should be available next month.
For NB+ we only have H4 but other bases should be available next month too.
We also have available genuine Philips D2S.
If interested PM me or text/call 0919 991 7769. Please ask for Joy.
sir kamusta buga ng High beams with the bsoch 85 watts? sakin kasi, ONB+ and parang naka focus masyado yung high beams ko tsaka 55 watts so not much brighter than the oem. I plan to replace this with bosch white halogens na 85 watts pero issue ko yung pagiging focused ng high beams. dba dapat medyo kalat ang buga ng high beams?
Yung bosch 85W all weather on stock wirings ok pa rin. Throws long and illuminates wide (since this is the design of the reflector of the high beams. The high beams have a focused center and some surrounding cast off light. At 55W the cast offs are weak but at 85W it is more pronounced and lights up reflectorized signs not usually lit like EDSA overhead signanges and since yellow sya mas kita yung signs). If you plan to go 85W check your terminals muna kung kakayanin. Yes dapat mas kalat since you need to see farther and wider to see obstacles crossing or at the end of the road.... But it still depends on the reflector of your high beams...
Hope this helps out..
osram has 2800k while bosch has 2900k.
does it mean that osram all weather is yellower than bosch?
Ace is selling bosch all weather plus, 60/55w. what is peculiar about this is its bluish bulb. beside it is bosch star bright with 3200k also 60/55w. it has bluish bulb too. according to bosch' site, AW is yellowish.
i guess Ace wants to dispose this asap that's why they are selling it for P500 only. while star bright cost more than P900.
also had my car's HID removed last weekend.
got flosser bulbs (made in germany) for 350 pesos each.... 100/80w + relays + ceramic sockets.
