Results 631 to 640 of 747
- Jan 2011
- 34
December 28th, 2013 11:42 PM #631
January 9th, 2014 09:01 AM #633
northcustoms and Redline Auto Works has the Q5 and also installs them sir.
January 13th, 2014 08:56 AM #634
Finally had my HL retrofitted with mini H1 using F5 Fastbright ballasts and 5000K bulbs.
Some before and after output pics.
Using camphone only so it is autocompensating exposure.
Sent from my GT-N7100 using Tsikot Forums mobile app
- Jan 2011
- 34
January 13th, 2014 10:47 PM #635Congratz laki ng difference ng output compared to halogen.
55 watts ba yun F5 fastbright na gamit mo. Last time kasi when I was deciding the wattage ng HID na gamitin ko medyo nag dalawang isip ako when I read a post in hidplanet of a case na natunaw yun reflector ng projector using 55 w HID.
At first gusto ko na maximize yun light output kaso ayoko naman na masayang investment ko in case na ma burn reflectors ng projector kaya in the end I settled to 35 watts just to be safe.
Pero I think rare and isolated case lang yun and wala pa naman naka experience sa atin dito.
Check this: http://www.hidplanet.com/forums/show...s-on-FXR-1-1-s
January 14th, 2014 11:45 AM #636
^ Oo. Ang layo ng difference lalo na pag totally dark.
55W yung F5 fastbright. Initially wanted 35W lang but yung nagretrofit kasi either generic 35W or yung 55W DLT F5 fastbright ang available so yung F5 na lang for the same price. Parang mas maganda yung quality compared sa generic ballasts. Yun din naman recommended nya at may warranty naman. Meron na din syang Q5R pero lagpas sa budget ko kaya MH1 na lang muna. Based din sa mga posts sa hidplanet, maraming gumagamit ng 55W even sa generic MH1 na wala namang issue.
Iniisip ko din na kung masunog yung reflector bowl, papalitan ko na ng Q5R. Yung MH1 pala na ininstall ay yung may SUPER na nakalagay sa top ng bowl kung saan nakalagay yung ULTIMATE sa Ultimate MH1projector. Not sure kung ito yung previous version na pinalitan ng Ultimate or ito na yung higher end MH1 ng ibang manufacturer. Basta ok na ako na hindi sya generic MH1.
Napansin ko lang medyo nasa left ng cutoff yung hot spot ng passenger side. Malaki yung nahaharang ng cut off shield. I tweak ko na lang yung seating ng bulb pag may chance para gumitna yung hot spot. Baka gumanda pa ng konti distance lighting at width sa right side. Ok naman yung driver side. Tingin ko dahil ito sa generic H1 HID bulb na kasama sa kit na hindi swakto yung focal point sa reflector bowl.
Kayang kaya ng Q5R yung 55W. Malaki yung reflector bowl nyan. Yung unang version ng FXR may issue talaga na nagpepeel off yung bowl coating pag 55W. Sa mga newer versions nacorrect na sa pagkakaalam ko. Nasa V3 na ata ngayon.
January 14th, 2014 12:13 PM #637
kakainggit naman. haha sarap mag-projectors uli. how much pag yung q5r projectors package with install? kahit PM na lang para hindi OT hehehe
January 14th, 2014 03:28 PM #638
I'm using generic mini H1 then 55w ballast, ok naman. Best decission para saken kesa mag mount ng pair of fogs ... hopefully no issues sya. So far so good :D
Sent from my GT-I9300 using Tsikot Forums mobile app
January 14th, 2014 10:26 PM #639
^kanino kayo nagpa install sir? and please post some output pics? thanks!
January 15th, 2014 01:15 AM #640
*sirbossr,
may nabanggit na seller/installer a few pages back. he's in sulit.com ata. paolo something hehehe planning to get a unit from him also if my budget permits.
high idle RPM at engine start
