Results 181 to 190 of 747
March 14th, 2011 01:23 AM #181
*kkreuk18, thanks for the feedback.
*renzo, wala pa pambili ng retro fit eh. hehehe
March 14th, 2011 04:43 AM #182
installing projectors ( aftermarket / OEM ) inside a halogen headlight is considered a retrofit.
aftermarket : FX-R , mini H1 / D2S , G1-G5
OEM : LS460/430 , TL , FX , E55Last edited by Ginnova; March 14th, 2011 at 04:51 AM.
March 14th, 2011 10:53 AM #183
- Dec 2002
- 2,335
March 14th, 2011 11:34 AM #184renzo: the output on the wall is totally skewed. The passenger side is higher and not leveled with the driver side output. Not all "bolt ons" are just that, bolt ons. You need to make some adjustments to correct it. Nandun kana rin tamain mo na right?
Yung second picture mo looks familiar. Saan ko ba nakita yan?
The Philips Germany bulbs will not alter significantly the output of a setup na naka China bulbs, assuming both bulbs as functioning well. Especially pag a few months old pa lang pareho. You buy the oem philips for long term reliability as the 85122+ will not color shift and will stay 4300k all of its lifetime. FYI lang. Some peeps want the 85122 as it will color shift to around 5000k. I've been using the 85122+ for more than 2 years now and perfectly satisfied with it.
- Jul 2006
- 34
March 14th, 2011 12:56 PM #185
March 15th, 2011 11:54 PM #186
*sir garyq, parang hilaw kasi un lumens nun china bulbs na kasama nung projector compared sa 85122+. nakapaginstall ka na ba nung osram CBI? Parang ang ganda nun.
- Dec 2002
- 2,335
March 16th, 2011 12:31 AM #187
March 17th, 2011 11:39 AM #188
*Ginnova,
Question. You mentioned that you added a spacer to get the bluish cut off. May I ask where you made that addition?
March 17th, 2011 02:09 PM #189
Stock projectors should have a blue color above the cut-off, even the halogen projectors. So if want more color or a sharper cut-off , you need to space either the bulb, shield, the lens or all of the above. you need to experiment.changing the bulb sometimes changes the color. it will depend on the projector. what kind of projector do you have.
March 21st, 2011 03:11 PM #190
Ok, thanks for your inputs sir. I have a gen 1 bolt-on. Just got intrigued by how strong the blue line is at the cutoff ;)
