Results 1 to 20 of 38
    Dec 2009
    Hi guys, i own a 2011 mitsubishi adventure. Nabulag kasi yung right side ng headlight ng advie ko. Pero pag naka bright may ilaw naman.. Sa bulb na kaya yung depekto non or sa wiring lang? Thanks!
    Sent from my LG-P920 using Tsikot Forums Mobile App mobile app
    Aug 2004
    Pundido na low beam filament mo. Replace bulbs in pairs kahit ok pa yung kabila. Use stock wattage bulbs lang. 200 lang ata isa sa Ace nyan. Dont get the fancy colored bulbs.
    Sent from my GT-N7000 using Tsikot Forums Mobile App mobile app
    Dec 2009
    Safe ba gamitin yung tig 200 sa ace hardware? Last time kasi na ngyari yan sa casa ko pa pinaayos. It cost me 2500 sa isang bulb at labor
    TY sa suggestion sir.
    i replace only the busted bulbs. no point in replacing a bulb that ain't busted. my ride's right headlight bulb got busted 5 years ago. my left headlight bulb is still original factory..
    and yes, everything is expensive in the casa... except the sales talk.
    a 20 peso bulb on the outside costs 200 kesos in the casa. but this includes installation... as if it's very difficult to reach in and turn...
  5. #5
    daan ka sa shop, bigyan kita isang piraso. H4 yan, OEM pa bigay ko syo.
    Quote Originally Posted by garyq View Post
    ako na lang ang daraan! para may spare... heh heh.
    Aug 2004
    Quote Originally Posted by radz15 View Post
    Basta Osram or Narva. Yung mga pangit ang box. Wag yung mga Circuit etc.
    Rule of thumb ko kasi yang replace in pairs. Nagsimula sa brake lights dahil laging napupundi yung isang side lang. Nung pinalitan ko sabay tumagal na. Your mileage may vary though
    Mar 2015
    I have the same problem as TS. Where can I get the headlight replacement bulb for Chevy Cruze? Nakita ko sa youtube ang bulb item number ay H13LL. Or pwede ba gumamit ng iba? Thanks
    Jun 2012
    ^Kelangang H13.
    Sep 2017
    Just use a simple tester to check if there is resistance and continuity para di masayang pera mo mag invest sa di kailangan if you're just using typical 55w or lower powered bulbs. But if you're using something like 90w or higher bulbs then you definitely need a relay kit for that one. Ang grounding kit madalas e di mo na kailangan kasi madalas may nakakabit na sa body ng saskayan mo to dispose the charge.
Headlight  problem
