Page 1 of 2 12 LastLast
Results 1 to 20 of 96
    im planning to change my fog light, yellow or white? what are their advantages and disadvantages?
    In real foggy conditions, yellow is better.
    In typical city driving use, white (3000 to 5000 kelvin temp) is better.
    Note: super white bulbs look nice but are useless when it rains.
    from the two, ill go for yellow na lang pero given another choice, all weather bulb for me.
    physics wise, yellow. but i wish their users aim them the right way, that is, low. even lower than lo beam headlights. otherwise, nakakasilaw sa oncoming motorist. white? like the man said, white is useless as it only illuminates the rain and smoke/fog infront of it and nothing more.
    Right now i have a white bulb . Planning for a change to buy all weather bulb.
    yellow for me. white, for pogi points lang...
    Feb 2009
    People try to be different even if it is illegal. Some people just want to be noticed. The exterior vehicle light are what you see in limited light and can mislead, confuse, distract or irritate some drivers. The only colors permitted by law for a POV are headlight clear, amber for front clearance light and turn signal and red for tail lights and stop lights. Imagine a deviant car that uses green lights for stop lights
    between the two, go with yellow. you cannot see white if it is raining for it reflects with the water on the ground.
    Nov 2016
    Quote Originally Posted by dachshund View Post
    ithink it‘s better choose a yellow
    one
    Aug 2012
    Re: Yellow vs White light. It more depends on your preference and eyes. Some people see more with Yellow light. Some people see more with White light. Go with whatever is comfortable to you.
    There are cars that come with White light as stock already for both headlights and fog lights.
    Sent from my ASUS_Z010D using Tapatalk
    Quote Originally Posted by red_one View Post
    it wouldn't be a proper foglight bulb if it weren't yellow.
    Aug 2012
    Not really.
    There are two camps on this. There are articles that says White light is better than Yellow. And there are articles that says Yellow light is better than White.
    I say go with whatever that works for you.
    Not really.
    that is so, sir. diff'rent strokes for diff'rent folks.
    but physics says yellow is the proper color of foglights. that is, if you use foglights for what it is named after... fog. or rain. or smoke.
    but if you use it "for show", then i suppose any color under the rainbow is the user's personal choice.
    Aug 2012
    Despite common assumptions, the yellow color of fog lights does not improve visibility in fog.
    Misconceptions
    The belief that yellow fog lamps contribute to superior lighting in foggy conditions is based on a misinterpretation of physical laws about the behavior of light which hold that colors at the shorter wavelength end of the spectrum disperse more easily in interactions with small particles. Longer wavelength colors like yellow were thought to be less subject to this effect.
    Reality
    In fact, the large size of fog droplets negates any significant difference in scattering effects among colors.
    Filtering
    “Yellow” fog lights are actually just filtered white lights. Since the filtering naturally reduces the emission of light, it does not boost its power to cut through mist.
    Origins
    The use of yellow as a color for fog lights may have started because of a genuine misunderstanding about its ability to illuminate foggy roads. After that it may have simply become traditionally accepted. An alternate theory holds that yellow is associated with danger and indicates hazardous conditions.
    Misconceptions
    Reality
    Filtering
    Origins
    perhaps TS should try both and see.
    but i wonder, does TS intend to use it for fog or rain, or for "something else"?
    btw, i think the use of foglights in the metro is still illegal.
    yellow foglights.
    Aug 2012
    Reality is many are using foglights even without rain or fog. Drive at night and you will see many cars with foglights on here in Philippines.
    Reality is many are using foglights even without rain or fog. Drive at night and you will see many cars with foglights on.
    yespo. and i find them, squint-able. nakakasilaw yung iba!
    i used to have yellow fogs, many, many years ago. i found them a significant help in the rain , at night.
    tinanggal ko, dahil "i could see the oncoming motorists, squinting". nakakahiya.
    Jul 2017
    Well either reason is mahina na low beam or masyado malakkas hi so settle sa middle, foglighths on hehe
which is better yellow or white fog bulb?
