Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
    #21
    i read somewhere that LEDs are overvoltage-sensitive. if they are given more than their rated voltage, they glow much brighter, but their lives are drastically shortened..
    someone recommended somewhere in this forum, an off-the-shelf solid-state voltage regulator to maintain correct voltage..
    Jun 2012
    #22
    Quote Originally Posted by AC View Post
    so they may work sa 24v?
    LED Strips come in 12v or 24v application.
    There are also what they call "cuttable". Example, cut them by 3 or cut them by 6.
    Ask the shop selling them.
    May 2012
    #23
    you can connect two similar led's in series. para maging equal ang voltage across the leds, install a resistor in parallel with each led.
    to increase their life expectancy, a more complicated way is to parallel the 24v leds with a 1watt, 24v zener diode with a series resistor. the value of the resistor depends on the led current. ipagawa mo na lang sa experts.
12v to 24v led?
