Results 111 to 120 of 184
- Jul 2016
- 1,178
March 18th, 2018 11:08 AM #111Mag unleaded yung pinaka mura na lang kayo. Kasi sa gas station pag nag drain na sila.ng laman ng tanker lahat ma drain nila ilalagay nila yan Sa pinaka mahal product. Hindi ko sinasabi lahat ganyan ginagawa pero karamihan ganyan ang procedure.
Sent from my vivo 1606 using Tapatalk
- 54,263
March 18th, 2018 11:42 AM #113
For everyday use. Kung ano yun pinaka mura, “unleaded” which is naging generic term na ng cheapest gasoline sa gas station.
Pag nag out of town and higher chance na meron mahahabang long stretches na mabilis ang takbo. That’s the time na nagpapakarga ako nun highest RON rating na available sa gas station.
- 54,263
March 18th, 2018 11:45 AM #114i fill up before goin' on a long trip.
ayaw kong magpa-gaso sa province.
i don't trust the quality of the gas stations there.
March 18th, 2018 11:49 AM #115
Only if your engine requires it. However, if you’re driving a low performance subcompact or compact with a small output engine, I guess you are better off with the 91RON.
My turbo rides requires 95RON minimum so I use XCS (fleet card so it’s free) or SeaOil Xtreme97 (2 pesos cheaper).
- Mar 2013
- 6,160
March 18th, 2018 12:53 PM #116Blaze has actually less power than 91 octane because it is less dense BUT it is needed by high compression high power engines because the lower density prevents premature fuel detonation in the cylinders. High compression engines develop more power but at the risk of pre spark detonation if fuel mix is too rich. Using Blaze leans out the mixture a bit.
Engine ECUs are smart enough to detect engine knock due to fuel type and advance or retard the spark timing as needed. But you will lose power.
Sent from my SM-N950F using Tapatalk ProLast edited by EQAddict; March 18th, 2018 at 12:55 PM.
March 18th, 2018 01:13 PM #117
Ayan oh, sabi ni EQ. If you don’t have a high compression engine that requires high octane fuel, there will be no gains using Blaze100.
- Mar 2013
- 6,160
March 18th, 2018 01:15 PM #118
March 18th, 2018 01:30 PM #119
Is the Forester's fb20 a high compression engine?
Sent from my SM-T705 using Tapatalk
March 18th, 2018 01:44 PM #120
The FB20B is not considered high compression, usual 10:1. The newer FB20D on the new XV/Impreza has a higher compression ratio but still not higher than the FA20 (NA for BRZ and turbo for WRX/FXT), around 12.5-13:10.
Mazda’s SkyActiv gas engines have higher compression ratio, around 13-14:10.
Sent from my iPhone using TapatalkLast edited by Egan101; March 18th, 2018 at 01:50 PM.
I’m inviting anyone who's curious, motivated, or just ready for something different to watch a 100%...
Aircon auxilliary fan
