FUEL CATALYST
More horsepower and torque.
Just drop in the the tank. The Fitch fuel catalyst will transform the fuel in your machine so that it will burn cleaner and more efficiently.
HOW IT WORKS
All fuel possess elements that cause ignition problems. Some of these elements burn too fast causing pre-ignition and some burn too slowly causing delayed ignition, excessive smoke and carbon buildup. It is these troublemakers on which the Fitch Fuel Catalyst works. The catalyst alloy further refines the fuel to reduce these elements resulting in improved combustion, fuel savings, reduced emissions and increased power.
MORE HORSEPOWER, MORE TORQUE
Feel the power and make the climb with improved horsepower and torque with one installation of the Fitch Fuel Catalyst. Use of this product typically adds 3-5 hp and ft. lbs of torque. It's not a fuel additive! It's new technology that improves every tank of gas permanently..
KEEPS FUEL FRESH, EASIER STARTING
No longer will you deal with the hard-starting machine. The Fitch Fuel Catalyst means you never have to buy another fuel stabilizer or octane booster again!
This technology is always working to keep your fuel fresh, even in the off season.
