Results 1 to 5 of 5
    http://bioenergy.checkbiotech.org/ne..._smog,_deaths/
    [SIZE="5"] Study: ethanol may cause more smog, deaths[/SIZE]
    June 1, 2008
    WASHINGTON - Switching from gasoline to ethanol - touted as a green alternative at the pump - may create dirtier air, causing slightly more smog-related deaths, a new study says.
    Nearly 200 more people would die yearly from respiratory problems if all vehicles in the United States ran on a mostly ethanol fuel blend by 2020, the research concludes. Of course, the study author acknowledges that such a quick and monumental shift to plant-based fuels is next to impossible.
    Each year, about 4,700 people, according to the study's author, die from respiratory problems from ozone, the unseen component of smog along with small particles. Ethanol would raise ozone levels, particularly in certain regions of the country, including the Northeast and Los Angeles.
    'It's not green in terms of air pollution,' said study author Mark Jacobson, a Stanford University civil and environmental engineering professor. 'If you want to use ethanol, fine, but don't do it based on health grounds. It's no better than gasoline, apparently slightly worse.'
    His study, based on a computer model, is published in Wednesday's online edition of the peer-reviewed journal Environmental Science and Technology and adds to the messy debate over ethanol.
    Farmers, politicians, industry leaders and environmentalists have clashed over just how much ethanol can be produced, how much land it would take to grow the crops to make it, and how much it would cost. They also disagree on the benefits of ethanol in cutting back fuel consumption and in fighting pollution, especially global warming gases.
    In January, President Bush announced a push to reduce gas consumption by 20 percent over 10 years by substituting alternative fuels, mainly ethanol. Scientists with the Environmental Protection Agency estimated that could mean about a 1 percent increase in smog.
    Jacobson's study troubles some environmentalists, even those who work with him. Roland Hwang of the Natural Resources Defense Council, said that ethanol, which cuts one of the key ingredients of smog and produces fewer greenhouse gases, is an important part of reducing all kinds of air pollution.
    Jacobson's conclusion 'is a provocative concept that is not workable,' said Hwang, an engineer who used to work for California's state pollution control agency. 'There's nothing in here that means we should throw away ethanol.'
    And Matt Hartwig, spokesman for the Renewable Fuels Association, the largest Washington ethanol lobby group, said other research and real-life data show 'ethanol is a greener fuel than gasoline.'
    But Jacobson found that depends on where you live, with ethanol worsening the ozone problem in most urban areas.
    Based on computer models of pollution and air flow, Jacobson predicted that the increase in ozone -- and diseases it causes -- would be worst in areas where smog is already a serious problem: Los Angeles and the Northeast.
    Most of those projected 200 deaths would be in Los Angeles, he says, and the only place where ozone would fall is the Southeast because of the unique blend of chemicals in the air and the heavy vegetation.
    The science behind why ethanol might increase smog is complicated, but according to Jacobson, part of the explanation is that ethanol produces more hydrocarbons than gasoline. And ozone is the product of hydrocarbons and nitrogen oxide cooking in the sun.
    Also, the ethanol produces longer-lasting chemicals that eventually turn into hydrocarbons that can travel farther. 'You are really spreading out pollution over a larger area,' he said.
    And finally, while ethanol produces less nitrogen oxide, that can actually be a negative in some very smoggy places. When an area like Los Angeles reaches a certain high level of nitrogen oxide, that excess chemical begins eating up spare ozone, Jacobson said.
    Hwang agreed that that is a 'well-known effect.'
    While praising Jacobson as one of the top atmospheric chemists in the nation, Hwang said he had problems with some of Jacobson's assumptions, such as an entire switch to ethanol by 2020. Also, he said that the ozone difference that Jacobson finds is so small that it may be in the margin of error of calculations.
    Jacobson is also ignoring that ethanol - especially the kind made from cellulose, like switchgrass - reduces greenhouse gases, which cause global warming. And global warming will increase smog and smog-related deaths, an international scientific panel just found this month, Hwang said.
    somehow I am not surprised with this...
    along the way, scientist will tell us that this is that pala... too late...
    haayy... ano ba talaga kuya...
    another petroleum company sponsored study/scientist? wait til they find out that wind, solar and water sourced energy kills more people than petrol.
    Somehow I am not clear why ethanol could cause more deaths? What model did the author use? And how did he assumed that emissions from ethanol are partly caused this respiratory cases???
    Although said he is respected in his profession it still all boils down to data. Where is the data?
    Jacobson's conclusions sound awfully fishy to me, given the highlighted facts. He fails (perhaps conveniently?) to state that not switching to ethanol will cause far more deaths in the long run than switching to it. We should be sure indeed that this study isn't sponsored by some petroleum company or industry group.
