[SIZE=2]my brother wants to know how it is different from Khaos and if it is advisable. as per my brother, it is similar to a catalytic converter.
TIA [/SIZE]
TIA [/SIZE]
I can safely say it probably does not work... Octane booster? Hydro? Labo naman nyan. Octane can only be increased generally if you use fuel additives. Do you have a link to the product page or a description of the thingie?
Does the *inventor* even know how a REAL flux generator works? :bwahaha:
HYDRO-OCTANE BOOSTER
Hydrooctane booster with electromagnetic flux generator and catalytic converter can reduce emission by 50% on the average, and reduce fuel consumption without sacrificing on power. It makes the engine burn fuel more efficiently, eliminating wasted fuel back-wash. It has no moving parts and its permanent electro-magnetic field is warranted for life as a permanent system in your fuel line.
* Features: Works on diesel or unleaded gas engines
* Easy to install
* Maintenance free
* No moving parts
* Benefits: 10% to 20% savings on city driving or up to 40% on highway driving
* Smooth engine starts and running
* Clean combustion system – no carbon/varnish build up
Hydro-Octane Booster US$ 199.50 (inclusive of express delivery charge)
hay,e2 ung nakita ko sa cherry foodarama(congre.) last monday...kung sana madinig nyu ung testimonials nila, im sure mattwa kyu!eto ung natatandaan ko testimonial nila:
"kahit di mo daw apakan ung gas, di daw namatay ang makina!"-->hello, kung a/t, di talaga noh! sa m/t it will run too!
hindi ata marunong mag drive. :bwahaha:"kahit di mo daw apakan ung gas, di daw namatay ang makina!"
hindi ata sila marunong sa kotse, most modern cars eh hindi na madaling mamatayan ng makina, diesel nga eh tatalsik ka pag nabitawan mo clutch heheOriginally Posted by alwayz_yummy
Di ko nga maintindihan yan eh, lagi ko nakikita sa Cherry sa Congre. Parang ang gulo ng principles nya. Nakakatawa din yung video nila hehehhe.
yah, thier video somehow makes me laugh......malapit ka lang din pala sa cheri sir dbulido...
mukha nga regular na ata un doon..may showroom(or office..ata) sila dito sa visayas avenue, malapit sa equitable PCI, katabi ng DHL!
nahihiya ako mag-inquire...baka bigla ako matawa sa video testimonials! :bwahaha:
to always yummy: I live near Proj6 too.
hahaha. I also saw that in Cherry Cong. Ang kukulit pa ng mga tindero. "sinabi nang di ako bibili!!"
They are like those FAMILY FIRST agents na makukulit sa malls. Binibilisan ko ngang maglakad para di ako abutan.
u said it pa....ganun pala dun, para bang ahente ng "family 1st"? oh well, kasama ko naman si misis, susungitan din nya sila..
for me, wala pang additives/gas-saving devices na napabilib ako, except ung pinaka-original blend ng pertua..sayang at nabenta na ung name sa kung sinong money-monger na businessman..kay di na effective kaysa noon..
So that is the reason pala kung bakit hindi na kamukha ng dati ang results ng pertua treatment ko. The best yung original dahil hindi mo nga mamamalayan na nakasindi pala ang makina mo sa sobrang tahimik. Now, walang change sa engine. Maingay pa rin despite the treatment.Originally Posted by alwayz_yummy
hi ghosthunter, im new to this forum, i actually just submitted here an ad yesterday promoting HOB. i found your tony article very interesting. for yourself, what is your criteria for the effectiveness of a fuel saver aside from improving your mileage and maintaining your car's normal working performance?Originally Posted by ghosthunter
since you were the one who posted this tony article, and you are a moderator here, id like to invite you to come to our headoffice in QC (near ABS-CBN Compound), so we can show to you the principles and theories behind it, and likewise, so that you can get to meet HOBs humble inventor, Mr. Glenn Castillo. bring along a few of your friends if you like.
the AVP and the flash demo i uploaded can only do so much, actual demo is always the best.
tell me your convenient date and time (early next week?), we'll make sure it'll be worth your while.... hoping for your confirmation on this one. cheers!
ghosthunter, id like to invite you or anyone here in our upcoming events:Originally Posted by ghosthunter
Sept 24, 2005 - Drag Racing Event Sponsorhip
At Diosdado Macapagal Hway, Pasay City
Sept 28, 2005 - Truck Show At SM Megatrade Hall
Oct 02, 2005
allow us to enlighten you that what we're selling here is not a myth. if you just wanna go there unannounced or 'walk in' query lang, ok lang din, just visit our HOB booth, and look for Mr. Glenn Castillo - the inventor and manufacturer.
Cheers!
HOB Info and Links
http://img363.imageshack.us/my.php?image=diagram2lm.jpg
http://www.geocities.com/rj_hob/HOB.html
http://p083.ezboard.com/fmotioncarsf...cID=2675.topic
from the description in the diagram above and cutting through all the marketing blabber... the device is basically a fuel heater. It's designed to "preheat" the fuel (gasoline or diesel) before reaching the combustion chamber. It's effect is to increase the volatility of the fuel at the point of combustion.
Example, cold diesel fuel will not catch fire but hot diesel fuel will catch fire easily.
I have read other versions of this type of device where the heat is derived from the exhaust pipe. A length of copper tube is wrapped around the exhaust pipe and is connected to the fuel system. The problem with this specific design layout is the fuel tends to get overheated and boil, causing the engine to run erratically and even stall (due to bubbles of fuel vapor in the fuel line).
Anyway, from what I have gathered, this gadget can improve milage but only marginally (5% or less).
I assume people will ask, "Is this device worth buying?"
Vehicle Type - Radiator Hose Diameter - Price
Cars / AUV ________- 1.25" - P7,500
Cars / AUV / SUV ___- 1.50" - P7,500
SUV ______________- 1.75" - P8,500
Trucks / Bus _______ - 2.00" - P8,500
Large Trucks / Bus __- 2.50" - P9,500
My answer, no... it will take years to get back your investment.
if that's the case, then pwede yan siguro for diesel cars running on a veggie oil/diesel mix in cold countries. the veggie oil tends to produce lumpy running if in cold countries because it solidifies/tries to more easily than diesel.Originally Posted by ghosthunter
hehehehe...mapakita nga sa nasa pajero owners' club UK. heheh.
wandering a bit ot...i saw their booth too at cherry congressional (lapit din lang kami dun) but di na ako lumapit, nagmamadali ako umuwi to rest after buying a gift for a friend (napagdisketahan pa ako ng salesladies ng perfume). hehehehehe...
We very much welcome all the experts here to see us in the office. Bring it on!
Hmmmm ... pero what's in it for you?
* If you're happy, you'll buy and maybe you'll become a dealer also.![]()
* If you're not happy with the discussion, and the BS that you thought it was, was validated, then you've proven that magaling ka talaga.![]()
HOB Office - Tel: 455-1555
5/F Benjamin Bldg
Sgt Esguerra cor Mo Ignacia Streets
In front of abscbn tower
Peace!
Typical construction for this device will look like a section of metal tubing (sized to fit the radiator hose of your car) and some copper tubing coiled tightly around the metal tube.
Basically anyone handy with a metal saw and pipe bender can build one in an hour or so. Not worth the P7500 to P9500 asking price.![]()
add this to your list... a reasonable price for the gadget so that the ROI time will not take the entire useful life of the vehicle, in which it is installed in.Originally Posted by kali_rj
Unfortunately I am both typically busy and rather camera shy & not given to personal appearances. Maybe I might visit your booth at either mentioned events (rallycross & carshow).since you were the one who posted this tony article, and you are a moderator here, id like to invite you to come to our headoffice in QC (near ABS-CBN Compound), so we can show to you the principles and theories behind it, and likewise, so that you can get to meet HOBs humble inventor, Mr. Glenn Castillo. bring along a few of your friends if you like.
BTW, did I guess the gadget's function correctly?
Ang tagal nung sagot.... baka nagre-research pa.... after 30 years pa yata sasagot, mukhang natumpok ni ghost e.Originally Posted by ghosthunter
