Results 31 to 32 of 32
October 4th, 2016 10:52 AM #31
October 4th, 2016 04:38 PM #32
Won't ever get there.
The Partial Gas Law means that oxygen will only leak out until it equalizes with the outside air.
So, if your tire is inflated to twice atmospheric pressure... about 30 psi (from 14.7 psi), and outside air is only 20% oxygen, then your oxygen will leak out until you have only 10% oxygen inside. Inflate to higher pressures, like I do, and it'll get down to about 6-7%.
As an aside... most pump nitrogen is only 93-95% pure.
One interesting idea, and I've mentioned this before... is using refrigerant to fill tires. I know one guy who's experimented with this, and has found that the tires hold their pressure much longer still... though filling with refrigerant is obviously much more expensive than nitro-filling!
Lately, I've been seeing a number of ads in my Feeds about a certain aftermarket high-CFM auxiliary...
