Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
    Aug 2004
    #21
    Aren't airliners at 100 psi?
    Around 200 actually. And they burst test them with water instead of air. A tire bursting at 1000 psi of air tends to bring down any structure within a 50-foot radius
    BTT: Airlines use nitrogen in their tires due to the temperature fluctuations between the freezing cold at cruising altitude to the scorching heat of a fully loaded landing.
    #22
    If its free why not!
    Since I always get free refills and dun din naman ang suki ko na vulcanizing shop binabalik balikan ko din.
    Jul 2006
    #23
    Isn't air (this thing we are breathing in) about 70-ish% nitrogen?
    Aug 2004
    #24
    Yeah... even truck tires at 300 psi can wreck steel burst cages.
    78%, as close to 80% as makes no difference.
    #25
    I air up in an even more convenient place.
    My garage.
    Pumping four tires to 55 psi by foot is good exercise.
    I don't know what will raise more eyebrows... the 55psi or pumping the air by foot.
    Free refills right?
    Yep. That's the only reason why i get nitro pa rin with our cars that get "tired" at S&R. For the rest, i just go to the gas station.
    Mar 2004
    #26
    Pumping them by hand is even better ... used to do it using air compressor but it took longer to set it up and store it compared to just using a hand pump ...
    Aug 2004
    #27
    Calves of steel, baby. Calves of steel.
    The foot pump is more compact. I keep it under my seat.
    Not too impressed with the hand pumps I've seen, but it would be nice to have a good one for use around the house.
    #28
    As I have stated on the first page, air is composed of 78% Nitrogen, 21% Oxygen, and 1% other gases.
    Jul 2013
    #29
    More to the point, since oxygen permeates through rubber more readily than nitrogen, eventually your 80% nitrogen fill (normal air) will reach about 90%, as long as you keep re-inflating it (at high pressure) with regular air.
    As the percentage of nitrogen increases, the air loss per week slows down.
    I haven't thougt of this. Mga ilang weeks kaya bago maging 99% nitrogen ang nasa loob ng gulong?
    #30
    Quote Originally Posted by Lew_Alcindor View Post
    Right before you're due for a tyre change?
Nitrogen vs Air in Tire
