Results 1 to 10 of 97
October 20th, 2006 06:19 AM #1
This is interesting:
http://www.popularmechanics.com/blog...s/4199963.html
"To invoke the MythBusters, we’d now consider the myth of increased fuel economy from over-inflated tires officially busted. So why didn’t the harder tires with less drag result in better mileage? Well, you’ve got to figure that, at 70 mph or so, the aerodynamic drag of the car’s body is probably outweighing the small improvements the tires gave us."
October 20th, 2006 09:38 AM #2
But how may of us actually drive at 70mph?
October 20th, 2006 11:34 AM #3
I wonder what would be the result if the speed was lower? ... say 40-50mph?
October 20th, 2006 11:58 AM #4
*otep: tama, it's way too fast * 110kph on our tight, short, metropolis roads. it will just guzzle up the fuel. (hataw mode ikanga!)
Our tires in our vehicles is about 3 to 5psi more than the recommended. 32-33psi on my sedan while 33 up to 36psi in our van,..improvements on gas mileage??? hmmm... can't really say though,.. there are many things to consider for increase fuel eco aside from over-inflating it. However, better fuel economy can be manifested on our basic 'drivng style' parin.
October 20th, 2006 12:43 PM #5
yup, same thought,.. it might be possible that they can marginally achieve a better result siguro.
Excerpt from PM:
The door placard on the Honda recommends 32 psi in all four tires. The sidewall says the maximum pressure for the tires is 50 psi. So for the trip to Arizona, we inflated the tires to 45 psi.Last edited by rayban7g; October 20th, 2006 at 01:00 PM.
October 20th, 2006 12:49 PM #6
Usually truck tires na ang may 50psi max pressure. The tires on the MB100 are also rated 50psi max just like on my Pajero. Of course I don't drive around with 50psi in them. hehehe.
October 20th, 2006 01:07 PM #7
OT: at least oks lang sa Pajs mo and some trucks w/ 50psi on it, hehe, walang prob dun! Yun nga lang nag raise ng question ko na how come ganun yung max. recommended psi sa sidewall of that tire for such a small car?!?... labo noh!!!... hihihi! Top of the line VTEC Jazz equipts a 185/55 15, so malamang max. pressure nun is around 44psi,... iba siguro classification ng gulong sa tate, hmmmm....
October 20th, 2006 01:08 PM #8
Parang semento na yan sa 50psi. Ganun din ata ang tire pressure ng GM EV1 dati.
October 20th, 2006 01:18 PM #9
yung mga electric cars na nakita ko puro nakaganyan eh, low rolling resistance/high pressure tires. the mileage might increases yeah, but i would imagine the ride will be horrible. lumampas pa nga lang ng 35 psi feel mo na yung tagtag eh..
October 20th, 2006 01:23 PM #10
high idle RPM at engine start
