Results 1 to 10 of 27
- Aug 2007
- 68
August 15th, 2007 10:31 AM #2
There are forums that explains FC (fuel consumption) computation.
Try the search thread function.
BTW, welcome po sa tsikot.
August 15th, 2007 10:37 AM #3
1. Go to gasoline station. (preferably near your house).
2. Reset trip meter. (it's the sub-function of the odometer (kilometers) display on your dashboard... check your manual on how to do it, but it's usually just a matter of holding down the button to reset it.)
3. Fill tank to the automatic cut-off (I.E.: "first click lang po")
4. Drive around as normal for a day or two... however long it takes you to use up the gasoline. The most accurate way to do this measurement is to use a full tank of gas, but if you can't wait that long, a half-tank is good enough.
5. Fill the tank again at the exact same pump... hopefully at the same time of day. ("first click lang po..." don't let them top it off to the brim)
6. Take the distance travelled on the trip-meter, then divide by the number of liters it takes to fill the tank again. That's your km/l consumption.
Take note: Your car's odometer is not accurate. Many odometers read a bit fast (around 1-5%). Thus, your km/l reading will be inaccurate by a little bit. I've gauged my odometer as being about 5% slow (against a GPS device), so when I measure 9 km/l, it's actually about 9.5.
If you don't have a GPS device, the only way to gauge odometer error is to check it against the kilometer markers on a smooth, level road (like sections of the NLEX). If there are hills, though, the KM markers go off a bit, too...
- Jun 2007
- 166
BANNED BANNED BANNED
- Jul 2003
- 2,267
August 15th, 2007 12:42 PM #5pag malapit na mapuno yung gas tank mo, automatic na magstop yung paglagay ng gas from the pump. may click sound yun.
that first click doesnt mean your tank is full up to the brim. that is why most gasoline boy will ask you if you want to fill it up to the brim or not.
dun sa mehod na nadecribe, stop ka na dun sa first click.
August 15th, 2007 12:46 PM #6
Haha... na-explain na pala ni fourtheboys...
You should never fill to the brim... it's dangerous, and potentially bad for your paint if it spills over.
It's also inaccurate in doing gas measurements... just let the pump decide what's full and use the exact same pump for the refill, so the automatic shut-off occurs at the same level.Last edited by niky; August 15th, 2007 at 12:48 PM.
August 15th, 2007 01:05 PM #7
so yung first click na yun eh yun ba yung handle ng gas cable ba tawag doon pag puno na? sensya na wala akong alam sa first click din eh...hehehe.
August 15th, 2007 01:09 PM #8
Titigil nang kusa yung pump pag puno na ang tangke mo; it will indicate so through a clicking sound. Pag tinanong ka ng gas attendant kung sagad ang gusto mo, just say no.
August 15th, 2007 01:20 PM #9
ah ganoon ba yun...so bawal pala ipasagad kapag magpapa-full tank ka...
thanks sa inyo mga sir at may natutunan nanaman akong bagong LESSON nito...hehehe..Im proud to be a Tsikot.com member...dami ka talaga matutunan dito, di ako nagkamaling sumali dito...ang problema ko na lang ay paano makakuha ng sticker...hehehehe..anyway! thanks ulit!
August 15th, 2007 01:31 PM #10
Just tell the gas boy to fill up your tank up to automatic.
They'll know what it means.
Besides, it's bad to fill up your tank to the brim.
You have to leave room for your fuel to expand.
Hope this helps.
:regards:
Gamet ko cone filter kapag ba malakas Yung higop Ng hangin servo motor na tlaga sir
LANCER Itlog (93-96) Owners - Please Post Here!
