Results 1 to 7 of 7
May 9th, 2007 06:02 PM #1
sino sa inyo taga mandaluyong at regular na nagpapakarga sa Shell Gas station in shaw blvd, the one between acacia lane and 9 de febrero?
their unleaded is about P1.90/lit lower than most gas station (by the way most gas station in shaw blvd, mababa ang presyo).
the problem i noticed is when i fill up with them, mabagal ang hatak ng ride ko, hindi smooth and when i looked at the plug, medyo maitim.
i tried filling up at another shell in san francisco near municipal hall and the response is better, when i looked at the plug, it's cleaner. i've done this several times already.
im beginning to suspect that the former shell's unleaded is of low quality. could it be that they are not getting it from shell that is why they can give it at that price? imagine P1.90 lower.
am experimenting kasi with different fuels and i happen to encounter this.
anybody here can make a comment?
May 9th, 2007 07:33 PM #2
is that the shell near Nissan Shaw? Kung oo, parang totoo ang sinabi mo.. parang sluggish ang naging takbo ko nung twice ako nagpafull tank sa kanila... I suspect of dirty fuel.
I never came back to them after that.
Tsikot Member Rank 3
- Apr 2007
- 1,076
May 9th, 2007 07:53 PM #3i had the same experience with shell v-power..different stations tho...
kasi i always use v-power..and since taga proj7 ako..mas madalas ako sa shell along edsa cor veteran's vill...the hatak is ok...sa kanya pa lang kasi ako nagpapakarga...then when i had my tank fill up sa ortigas pasig cor dona juliana...mas ok takbo...ang saya...then nung sa CONGRESSIONAL near mindanao intersection..yung right side from munoz...bumagal hatak ko tsaka parang rough pag nagaaccelerate...i was worried...since alam ko naman na minsan talagang may daya mga yan...di na lang ako nagpapakarga ulit sa mga ganyan....kaya pag visit ko ulit mom ko sa pasig papa-fulltank na lang ako ulit dun..
May 9th, 2007 08:57 PM #4
ako taga mandaluyong malapit ako jan. NEVER nako nagpagas jan. Before kasi nagpapagas ako jan (DIESEL) then I noticed bumagal ang hatak ng pick up ko sagad na ang 120km/h at hirap na ang makina di naman kasi ganun yun dati.
Nung pinatingen ko sa mekaniko, papalitan ko daw yung fuel filter, ayun nung pinalitan nakita sa filter ko na may mga lumulutang na parang latak kaya nagbara yung hose/nozzle kaya pala ang hirap humatak at parang "nabibilaukan" pag ni rerebolusyon. then after palitan yung filter yung fuel tank naman pina drain din ayun puro latak/dumi ang nakita na lumulutang. bad trip talaga ako nun kasi pina full tank ko dun at yun nasayang dina nagamit puro latak kasi. after nun malinis lahat balik na sa dati ang takbo at hindi nako dun nagpapagas. mas malinis pa yung shell sa tapat ng puregold near honda shaw. Pero now i use caltex diesel.
Dinako nakapag file ng complain kasi para saan pa lesson ko nalang yun.
Then na alala ko yung area na yun ay FLOODED AREA nga pala! Lumulubog yung gas station nila pag malakas ang ulan totally lubog sa baha kasi may creek dun na maliit uma apaw yun pag malakas ang ulan, minsan pa nga not passable sa lahat ng vehicles. Yun ang dahilan kung bakit madumi ang gas nila. then after a year nagsara yun pinaganda lang nila yung station nila para mag mukhang bago pero ayun madumi pa din kaya bagsak presyo gas nila. lahat ng flooded area na may gas stations dapat iwasan yun.. My thread na dito nun e.....
- Jul 2004
- 1,540
May 10th, 2007 06:31 PM #6
May 13th, 2007 02:09 PM #7
yung petron c5 near market market going to expressway ok dun accurate ang gas stations nila .....
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
