Results 1 to 8 of 8
- Jun 2007
- 1,161
September 1st, 2011 08:34 PM #1thus the celerio is the most fuel efficient?
The best rides to combat high fuel prices | Inquirer Business
how about the new 2012 picanto?
September 1st, 2011 09:21 PM #2
Hard to say, as those figures were all taken at different times in different conditions. In fact, the Honda Jazz and Honda City in those runs are likely the previous generation GD-chassis CVT ones, not the current 5AT models.
September 1st, 2011 09:42 PM #3
- Jun 2007
- 1,161
September 1st, 2011 11:35 PM #4how about this one?
http://www.tsikot.com/kia-picanto-fu...t-in-doe-test/
BANNED BANNED BANNED
- Mar 2011
- 479
September 1st, 2011 11:49 PM #5
[SIZE=3]Basta diesel engines and whether it be 2.5-litre or 3.0-litre, simula't-sapol, maaasahan talaga ang mga Isuzu's.... Pinaka-matitipid at pinaka-matitibay na makina[/SIZE]
Isuzu D-Max 4×2 pickup (manual 2.5L diesel) — 20.57 km/L; you spend just P2.24 per km
Isuzu Alterra 4×2 full-size SUV (manual 3.0L diesel) — 19.44 km/L; you spend just P2.37 per km
- Nov 2011
- 14
November 18th, 2011 07:30 PM #6It is a factor of speed increases friction and resistance and requires more energy to overcome. Driving slowly is slightly less fuel efficient than driving at a constant speed of 55 or 60, but at a slow speed the wind friction is reduced and the fuel economy is less affected. It also matters if you are driving into the wind or if the wind is behind you and 'pushing' the vehicle.
- Feb 2012
- 2
February 15th, 2012 01:14 AM #7
February 15th, 2012 10:29 AM #8
Maintaining a steady speed, the engine uses very little power, and thus, very little fuel.
Under acceleration, the engine will use more power, and thus more fuel. Maybe five to ten times the fuel you use while cruising. Fuel which is wasted, because you will have to brake to a stop, afterwards.
This is not to mention the use of AC in traffic, which means that you're burning one to two liters of gas per hour while idling at the stoplights.
To save more fuel in the city, avoid idling at all costs. And try to never use your brakes.
To clarify, if you accelerate hard enough to need to use your brakes to stop at the next stoplight or traffic snarl, you're wasting gas. If you only accelerate enough so that you can coast almost to a stop at the next light, you're using as little gas as possible. This is known as pulse and glide.
Smart city driving avoids traffic lights, or avoids waiting at traffic lights. These new LED lights with timers are a big help. If you know you're not going to make the next green, you can slow down and coast, to minimize the time you'll spend waiting at the red light. You can also shut the engine down if you see that you will be waiting more than thirty seconds for the next green.
More extreme hypermilers will pulse and glide, even on the highway. The most extreme ones will turn off the engine and glide in neutral. This makes for some absolutely amazing mileage, but without the proper equipment (engine kill switch... manual transmission for bump-starting in gear), it's highly dangerous.
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
