Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Pagtatalo ng 4 na magkakaibigan na walang engineer. Humaba ang usapan at inuman ng walang conclusion.
    Pros: tipid sa gas, di masisira agad ang clutch lining, masaya habang nilalaro ang kalye sa pag tantiya ng speed at traffic.
    Cons: delikado, walang kontrol, matic auto ko bakit pa?
    Ano ba talaga advantage at disadvantage?
    Posted via Tsikot Mobile App
    With the advent of DFCO, there's no need to free wheel anymore.
    Deceleration Fuel Cutoff
    Search ko pa yan. So lahat na ba ng auto may ganito na? Doesn't say much on the web
    Ginagawa ko lang ito kapag manual ang dala kong sasakyan, takot ko kasi pag matic baka masira pa tranny kapag biglang pasok sa D habang gumugulong ang sasakyan.
    Di maganda gawin sa automatic ito, kasi pagbalik mo ng kambyo from n to d4, ang lakas ng transmission shock nito kasi dadaanan niya padin ung sequence na 1, 2, 3 & then 4 (depende sa speed). Kahit sa ordinaryong stoplight hindi ako nagneutral.
    Sabi ng iba malakas daw sa gas, sabi ko naman hindi rin. Parehas pa din kasi hindi ka nakaapak sa accelerator so meaning di magiinject ng fuel na more than sa minimum.
    Kaya pansinin niyo pag nakastop at naka neutral medyo mataas rpm, pagnaka-D mas mababa rpm.
    Kaya ako ganin kasi ayaw ko ng transmission shock kakakambyo.
    Hth.
    Transmission shock. Bagong kaalaman.
    Aug 2004
    DFCO meanse that your penalty for staying in gear is very minimal. But DFCO also causes enhanced engine braking.
    Sometimes, it pays to actually coast, because coasting down on DFCO results in much shorter coasting distances. Hypermiling freaks almost exclusively coast in neutral.
    As long as you don't engage the transmission again until after you've stopped, there's little issue. The clutch packs should stay disengaged. If you shift back into gear while coasting down, there is some issue, though most modern automatics automatically give you the right gear for the speed you're going, resulting in less shift shock (will still cause some wear, though).
    ^^&hehehe shift shock pala tamang term.
    In older cars I think DFCO required minimum rpms of over 2500 so it wasn't as effective. Now though I notice that my Ranger goes into DFCO as low as 1500 rpm.
    So effectively coasting distance is also prolonged due to less engine braking.
    I still alternate between coasting and DFCO depending on the situation, but 85% of the time I just let DFCO kick in yo.
    Jul 2011
    pano malalaman kung gumagana na yung DFCO?
    Quote Originally Posted by s10pao View Post
    I just assume that it kicks in when my instantaneous fuel consumption becomes 0.0 km/L.
    There is a reason why this practice (freewheeling, coasting in neutral) is illegal in most developed markets so I don't practice it.
    Jul 2011
    wala ka kasing control on instances na kailangan mo mag accelerate on emergency manuevers
    Aug 2004
    There are some people who not only freewheel in neutral during eco-runs, but freewheel with the engine off.
    Not a great practice.
    Sorry medyo na nosebleed ako sa mga terms. :rofl: Let's say MT car, pababa ng flyover I'm running 70kph, pinakawalan ko ang gas pedal, ano ang mas matipid, stay in top gear or shift to neutral? I always practice staying in gear dahil delikado pag neutral.
    Dahil sa DFCO ay malamang hindi na ko mag free wheel. Mas safe pa rin talaga pag in gear ka.
    Jan 2009
    The video I made 6 years ago demonstrating how keeping it in gear while coasting will result in better fuel economy.
    8th Gen Civic FD Fuel Injection Shut-off - YouTube
    Feb 2003
    yes sir that proves that the program in the Computer box really works. There's an interlock though..the TPS should be in good condition and the RPM should not be less than 1300rpm. So as long as the TPS indicates in 14 or close/idle and the rpm is above 1300 then the power to the Fuel injectors are cut off thus it saves fuels. I think it applies to all Honda EFI engine above 2000 model..not sure the exact years..but read it in the manual.
    Jan 2014
    pero kadalasan nakaka pag free wheeling lang naman kapag manual transmission dipo ba, ginagawa ko din are lalo na sa long drive at kung medyo malapit lapit na hihintuan at ganun din pag pababa ang kalsada..
Free Wheeling: Pros and Cons
