Results 11 to 18 of 18
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 11th, 2013 08:19 PM #12
1. Whats your budget? No more than 100k.
2. How heavy a load do you carry? Not so heavy, mostly clothes & retail goods so it should be covered, not like pick-up cabs. More like the FB L200.
3. Who will drive it? You or a company driver? Driver, but I'd appreciate something I can also drive.
4. Brand new or 2nd hand? Definitely not brand new. For the multi cabs, I'd like to get the local ones but how do you know when it's not clearly stated?
Thanks!!
To the MODS, so sorry to repost this. I made the mistake of clicking on "reply" instead of the "reply with quote" button. Thanks!
July 26th, 2013 10:39 AM #13
I have both L300 FB and Suzuki Super Carry (local name ng Multicab).
Generally mas ok L300. Matipid sa gas at mas madali sa pyesa. Imagine, from the 80's hanggang ngayon nagbebenta pa rin ng brandnew. Problema lang may mga lugar na hulihin sya for smoke belching maski well maintained. Pero may solution din, pwede ka magpa voluntary emmissions testing every 3 months, tapos may hawak ka na certification na ipapakita mo sa nanghuhuli. Mga 400 yata yun. Sa budget lang medyo kapos ka, nasa 120-140 ang starting price ng mga 2nd hand.
Sa Multicab halos lahat yan converted. Pati mga benta sa dealer na multicab converted din (nakabili kami sa Philhino, sama ng conversion). Yung Super Carry namin, nabili namin brandnew nung 89. Umaandar pa rin ngayon. Sa pyesa, halos sa Casa nalang ako nakaka order (discounted via member Zukiman, pero mas active sya sa 4x4ph.com). Ang local 4 cylinder, sa converted 3. For it's size, malakas sya sa gas, tapos namimili ng gas, high octane dapat gagamitin. Carbureted pa sya at maselan sa maintenance. May times na hirap i-start, maski bagong tune up.
July 26th, 2013 12:18 PM #14
Just my ten cents....
In choosing your delivery vehicles, you need to know how heavy your loads will be. Each vehicle has a rated net weight it can carry without damaging itself. Even if you say it's not heavy, it is best to QUANTIFY how heavy a box of clothes would be and how many boxes of them will you be loading in your van/truck at one time.
L300 FB is a light duty vehicle that may not fare well in the long term with heavier loads. May result in transmission issues with near-to-capacity loads.
Isuzu NVH van/truck is one of the lighter capacity of the NHR series (2 ton capacity). Only downside the access to the engine is through the driver seat which limits access. The usual NHR has a flip-cab design for engine access. Durable enough as long as you don't exceed rated weight capacity. First thing to go would be the clutch if you exceed capacity. The rest of the vehicle fares well. Overall, designed to last for decades with proper maintenance.
Kia K2700 doesn't seem to fare well in terms of durability.
Suzuki Multicabs is a hit and miss proposition because they're basically 2nd hand. Upside is they are cheap but the downside they may not have the load capacity to drive with your required loads.
Toyota FX is a so-so choice... still I would say check your load's weight first.
- Jul 2011
- 1,711
July 26th, 2013 12:21 PM #15
Consider mo din ung tricycle with modified side car, since kukuha naman din ng driver.
Laundry shop ka, so mga short trips lang yan, sisirain ang battery mo due to start and stops (hindi mag charge properly ang battery), so better go with a motorcycle na meron kick starter.
Low maintenance at operational cost and within your budget.
Regarding naman your requirement na gusto mo din i-drive, better have a separate vehicle for your needs, wag po pagsamahin ang pang negosyo car with personal car or mag taxi ka na lang.Last edited by Manilablock; July 26th, 2013 at 12:24 PM.
August 2nd, 2013 06:47 PM #16
I kinda agree to this. But still, multicab is a good option, yun nga lang medyo alanganin. My tito got one for his school service business, ok yung nakuha nya. Yung kapitbahay naman namin bumili din pampasada, sablay talaga hanggang binenta na lang nya.. Eto kasi ang patok sa Lipa eh. hehe
- Jun 2012
- 4,447
August 2nd, 2013 06:58 PM #17mas ok sana kung hilux fx or L200. pero mas mahal. kung hindi kaya, better choose L300 than multicab
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
