Results 1 to 8 of 8
August 25th, 2006 10:04 AM #1
bakit may leak doon mismo sa Injectors pwede ba e re-tight or put a tape lon... 4D56 Diesel Engine.
August 25th, 2006 11:10 AM #2
Nangyari sa sasakyan ko yan a few weeks ago. There's a brass bushing sa nozzle holder which seals the nozzle tips. This keeps the injectors from leaking. According to the technicians, numinipis ang bushing which causes the leak (air or fuel). Ang ginawa nila is pinalitan lang bushing --- around P500 plus labor. Since, ipu-pullout ang injectors para i inspect ang bushings, pina-recondition (cleaning) ko na nozzles ko. Naka-tipid pa ako sa labor and at the same time, nalinis ang nozzles.
August 25th, 2006 11:19 AM #3
copper, not brass.
teflon tape will not work. ptfe is for low pressure only. the fuel pressure in a diesel engine injector line is in thousands of psi.
August 25th, 2006 11:33 AM #4
Teflon Tape pala. kasi nakita sa injectors shop na nilalagyan nila ng teflon, tama si YEBO copper yata, pero sabi ng mekaniko bibili daw ako ng parang washer naman na may dalawang maliliit nga butas sa gilid, iba yung malaking butas sa gitna, pero nagtanong ako sa store sabi wala naman daw. saan kaya pwedeng bumili...
- Oct 2005
- 147
August 25th, 2006 10:55 PM #5baka, yung return lang ang nagleak. puwede higpitan yun pero kailangan meron pang counter rotate yung injector para wag sa head mapihit yung injector assembly.
August 26th, 2006 01:37 AM #6
Try mo sa CALIBRATION SHOP. Usually available ang mga parts na related sa injector sa kanila.
- Oct 2005
- 147
August 26th, 2006 09:27 AM #7
September 7th, 2006 01:43 AM #8
i had the same problem last summer , ang ginawa ko , pinacheck ko sa nag cacalibrate , then found ung mga dikitan ng tube , then pinahinang ko lang sa nag aacetelyn , copper ginamit , doin use teflon di gagana :D i tried it na rin eh just have it checked .
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
