Page 11 of 44 FirstFirst ... 78910111213141521 ... LastLast
Results 201 to 220 of 1155
    Apr 2004
    great news! at the rate that diesel is rising, it won't be long when having a biodiesel blend will be comparable, price-wise, to pure diesel.
    Oct 2004
    just read the other day na marikina is supporting the biodiesel movement. People in marikina are encouraged to use biodiesel as an alternative source to the high prices of diesel fuel.
    Oct 2004
    ako din after using biodiesel napansin ko may mga carbon deposits nung nagstop ako gumamit. (after magfulltank ulit ) Subukan ko ulit. Hindi kaya ganun ang nissan engines?
    Pero nung ginamit ko ang biodiesel very minimal ang usok ko lalo na pag high revs at matipid sa gas
    Mar 2004
    Just a query is biodiesel ok to use with CRDI engines? thanks
    Gregg
    Quote Originally Posted by gregg_g
    Gregg
    Mas ok kung biodiesel gamit mo sa CRDi.
    Jan 1970
    di kaya mas mainit ang combustion with biodiesel? established na ba na hindi? kasi if significantly hotter (which might explain the better burn), baka naman mag shorten life ng engines.
    I heard this is the case for other additives.
    Quote Originally Posted by Poops
    Sa palagay ko hindi naman, I've been using biodiesel for a year now and nasa normal temperature pa rin ang thermometer ko. Mas better burn lang siya dahil higher ang cetane rating niya.
    Hello!!! Just called Sharky's and I'm going to buy a carbouy of biodiesel on thursday. Sa june na kasi ako magpaparehistro kaya kelangan pasado ako sa emmissions harharhar. Now my question: Paano pumunta sa Sharky's???? di ako magaling maghanap ng lugar sa makati.
    Quote Originally Posted by jim
    Buendia going to Makati, turn right on Dian St. go all the way till last intersection. In front of you a little to the left is TAL building, andyan ang Sharky's, forgot the room no., parang 2J but not sure.
    nagmi-mix ba talaga yung biodiesel with diesel? kasi unang tingin ko e parang vegetable oil yung biodiesel e. para bang yung tubig e di nagmi-mix sa oil.
    kaya ko rin natanong to kasi may na-observe ako sa paggamit ng biodiesel e. parang nako-consume ko yung biodiesel na inilagay ko after approx 20kms of driving. after ko mag-fill up ng 20 liters diesel and 1 liter ng biodiesel e sandali lang na magiging smooth yung takbo ng revo namin tapos after 20 kms e balik na naman sa dati.
    btw, para masiguro ko na na-mix ng mabuti yung biodiesel e inilalagay ko muna yung 1 liter biodiesel pagdating ko sa gas station bago idagdag yung diesel.
    ano masasabi nyo? may pareho ba kayong observation?
    Quote Originally Posted by amacatan
    baligtarin mo pre...full tank ka muna bago mo ilagay biodiesel. and yes biodiesel and diesel are very compatible. it's not like an oil and water thing. both are nonpolar chemicals at are mutually soluble... check it out for yourself to be convinced. bili ka ng isang litrong diesel...haulan mo ng isang litro din ng biodiesel.
    again... the main benefit of biodiesel is reduction of tailpipe emissions... yung increase in horsepower...negligible lang yun... around 2% lang yun in a benchtest that I saw. inconclusive pa kung meron nga talaga increase in power and mileage... what's conclusive is that emissions are reduced due to improved combustion of the fuel and fuel lubricity is improved = fuel lubricity will mainly lubricate the fuel pump... not the engine internals.
    Ako naman biodiesel muna bago diesel, para pagpasok ng diesel sa tank nahahalo na ito.
    Mar 2005
    Pareho tayo Falken mag mix ng Bio-diesel with diesel. Add ko lang na I see to it that I will be traveling once nag-mix ako. This is to stir the contents in a stop and go situation. I do not know if consistency of mixing is attained by overnight parking at garage. Can anybody from senbel or garyq give us tips for the proper mixing?
  14. #14
    mga bros very accurate ang comments ni rsnald. Maganda ang solubility ng BD and it mixes very well sa diesel. I fill in first and bd after or sometimes naman the other way around As suggested try niyo sa maliit na quantity and you can see it mixes very well.
    Jul 2004
    i've read in another thread way back last year that BD is aggressive to ordinary rubber and might not be compatible with stock rubber fuel lines. is this true? do we really have to replace the stock ones and with what type? tia
    Quote Originally Posted by ram
    unfortunately, yes it's true. cocodiesel for one is a much more agressive solvent (has more dissolving power) than automotive diesel. ang specified rubber na resistant to biodiesel is viton rubber. that's the downside of BD. the upside of that is that its dissolving power will also ensure that your fuel lines (and fuel tank) is also clean, meron kang built in degumming solvent. afaik, all or most vehicles after 2000 have rubber tubing that are resistant to biodiesel.
    Aug 2004
    paano naman po yung mga vehicles na luma from 1980's to 1990's? safe din po ba gamitin ang bio-diesel para dito?
    Quote Originally Posted by mcbry
    no choice but to change rubber tubings/gaskets. simple rule of thumb, kung gasoline resistant rubber sya, resistant na din yan sa biodiesel. mas matapang ang gasoline vs. diesel in terms of solvency power.
    May 2005
    has anyone tried bioexceed nf seaoil? Nakasulat kasi sa bote na recommended nila is 200ml:20L. So ganun ang ginawa ko pero medyo mausok pa din sasakyan ko. Gaano ba katagal bago magimprove yung exhaust ko?
    Quote Originally Posted by laklak
    Mahal yang bioexceed and envirotek ng Flying V, Try to get Estrol from Senbel, kalahati lang presyo, parehong quality rin.
Biodiesel Rulez!!! [ARCHIVED]
