Results 11 to 20 of 32
May 13th, 2007 11:56 AM #11
May 13th, 2007 10:52 PM #12
10% ethanol is what engines need. Not 20%. But the Ford Explorer can run 70% +.
It gives better performance, cleaner emissions, and better mileage.iam3739.com
May 14th, 2007 10:18 AM #13
correction, 10% is what unmodified engines will run on without long term damage happening.
Cleaner (overall) emissions with ethanol if you also count the source of the fuel.
BUT ethanol give lower mileage than gasoline.
May 14th, 2007 02:53 PM #14
tanong sa never have tried until the implementation peeps...
did your vehicle consumption remains the same after the implementation?
while most peeps who are using bio-diesel ever since, claims it improved mileage...
our diesel vehicles seems having bad mileage lately...
though I'm not sure if it's because of the implementation. or just sabay bad timing lang sa weather...
and I hear fuel filter change schedule will be earlier.Last edited by rion; May 14th, 2007 at 03:23 PM.
May 16th, 2007 03:31 AM #17
May 16th, 2007 09:06 AM #18
- Dec 2002
- 2,335
May 16th, 2007 12:10 PM #19filter change on BD: been using BD (at least B5 to B10) for more than 3 years now on several of our vehicles. I do normal change of filters. Nung una to be on the safe side I changed it after 2 full tanks and wala naman extra gunk yung filter. Did this on a 9 year old trooper, a 2 year old crosswing and a 10 year old 4BE1 elf. After that regular change lang ng fuel filter based on the PMS.
improved fuel consumption: the main reason why we should use BD is for the environment. If you approach it with this perspective mas maganda yung experience. On the side, some peeps report better fuel consumption which is good and also many studies show tumatagal yung life nung engine because of the better lubricity ng CME.
May 16th, 2007 01:01 PM #20
I believe BD has higher cetane but lower BTU, and hence will have lower fuel economy figures/more fuel consumption. The boone for biodiesel users is that it's safer to the environment, albeit with more fuel consumed. But if you think of it, the cleaner burning the fuel, pero ganun rin dahil offset siya ng more fuel consumed. Of course it's more lubricated rin, but are the pumps there already pumping out ULSD?
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
