View Poll Results: BEST Unleaded Fuel: Shell, Petron or Caltex
Voters
127. You may not vote on this poll
  • Shell
    40 31.50%
  • Petron
    46 36.22%
  • Caltex
    11 8.66%
  • Total
    4 3.15%
  • Sea Oil
    13 10.24%
  • Uni Oil
    9 7.09%
  • Others
    4 3.15%
Page 10 of 17 FirstFirst ... 67891011121314 ... LastLast
Results 181 to 200 of 488
    Read this test, super lapit lang nung FC for both. Statistical tie.
    You mean the diesel test? These were the results then:
    Fuel Save
    Fuel loaded: 55.5l
    Kms run: 844.99
    FC: 15.22 kms/lit
    Nitro +:
    Fuel loaded: 54.9
    Kms run: 814.7
    FC: 14.84
    It's only one test run. Although the stats are close, translates to 30 kms more per tankful.
    I would think with gasoline, Nitro + is made with performance in mind so don't expect too much in economy.
    Mar 2012
    Sawi. 11.3 lang yung Nitro+ ko. Nag Caltex Silver naman ako, eto ang malapit sa amin e.
    Quote Originally Posted by maki mi View Post
    Tried 1 full tank of shell fuelsave, turned out 12km/liter. So decide to shift from Nitro+, kaso kahapon ang haba ng pila sa shell at may pump na bakante, kaya sumingit ako, wala palang fuelsave yung pump kaya ayun balik sa Nitro+. P1.95/liter pa naman difference. dapat maka 12.6kpl ako to justify the diff. otherwise olats
    I know it's placebo but I noticed that pag shell ako pa karga. Parang mas matagal maubos. Be it sedan, mid SUV or SUV.
    Oct 2015
    If 91 ron ang recommended ng manufacturer. Posible ba masira ang engine in the long run pag mas mataas na ron ang nilalagay? Ano ba ang nagagawa ng RON?
    You can use higher octane fuel. But whether the engine makes use of it is another matter. Minsan sayang lang.
    Oct 2015
    Pero di kaya mas mabilis masira ang engine?
    Nope. As long as meet mo ang minimum required octane. Pwede magkaroon ng problema kung mas mababa pa sa 91 RON dahil sa tope.
    Oct 2015
    I see. Thanks. Ok lang tumaas. Wag lang bumababa sa RON.
    Last question, pwd ba pag haluin ang different ROn Sa gas tank? Or need near empty bago mag lagay ng new type of RON?
    Quote Originally Posted by dishcom View Post
    OK lang, basta huwag mas mababa sa 91 RON. Pinaghahalo ko nga minsan different brands. Pareho lang naman chemical composition niyan. Siyempre huwag mo paghaluin diesel,kerosene at gasolina.
    Oct 2015
    Unleaded po ba ang XCS ng Petron?
    Edit:
    based on owners manual my car can run 91 RON or higher.
    Now on the cover of gas refill tank, it says "unleaded fuel only".
    Could there be a problem if i fill it with Petron XCS which is 95 RON..
    Aug 2004
    Quote Originally Posted by khenma0928 View Post
    yes, it is.
    Oct 2015
    Quote Originally Posted by mcbry View Post
    yes, it is.
    Thanks... Maybe i can try it next time... Though wala nmn prob kung i mix ko sya sa lower octane which is xtra advance.. Nka full tank kasi ako ngaun eh
    Oct 2015
    May nabasa ako na pag mataas ang ron na gamit mas mainit ang makina.
    Yan din sinasabi ng mga mangingisda na ayaw bumili ng unleaded dati (91 RON) kasi daw mas mainit kaysa sa dating Regular (83 RON).
    Aba ayun, 1 year later nung wala nang makuhang Regular eh biglang ok naman pala yung 91 RON.
    kapag nakasanayan na kasi ayaw na sumubok ng iba ganyan ugali dito sa pinas. bibihira lang yung mag try ng iba kung hindi mopa sasabihan ng masmaganda ito at effective hindi pa itry
    Walang problem paghaluin yan.
    Oct 2015
    Petron Unleaded Fuels
    Oct 2015
    Shell Unleaded Fuels
    Oct 2015
    Shell na lang ako. If tama ako parter ni hyundai si shell, kasi yung shell oil ang nakita kung picture sa manual nila na recommended oil.,
    Shell is also the local OEM lubes supplier of Mazda, Ford, etc.
    Toyota is supplied by Caltex, Honda by Idemitsu, Nissan by Total, and so on.
    Their OEM supplier has nothing to do with what fuel will work with the car. It's just a B2B partnership, but the cars can still use any fuel that meets their specs.
