View Poll Results: BEST Unleaded Fuel: Shell, Petron or Caltex
- Voters
- 126. You may not vote on this poll
Shell
40 31.75% -
Petron
45 35.71% -
Caltex
11 8.73% -
Total
4 3.17% -
Sea Oil
13 10.32% -
Uni Oil
9 7.14% -
Others
4 3.17%
Results 211 to 220 of 488
November 8th, 2015 12:39 PM #211
Tried 1 full tank of shell fuelsave, turned out 12km/liter. So decide to shift from Nitro+, kaso kahapon ang haba ng pila sa shell at may pump na bakante, kaya sumingit ako, wala palang fuelsave yung pump kaya ayun balik sa Nitro+. P1.95/liter pa naman difference. dapat maka 12.6kpl ako to justify the diff. otherwise olats
November 8th, 2015 12:41 PM #212
Impossible to get conclusive results from just one full tank unless you can ensure that your driving style and traffic conditions will be exactly the same.
Masyado talaga maliit yung difference between different fuel brands and octane ratings to have verifiable and reproducible results from ordinary driving (which is never identical).
November 8th, 2015 01:03 PM #213
November 8th, 2015 01:41 PM #214
November 8th, 2015 02:14 PM #215
I know it's placebo but I noticed that pag shell ako pa karga. Parang mas matagal maubos. Be it sedan, mid SUV or SUV.
November 8th, 2015 02:22 PM #216
You mean the diesel test? These were the results then:
Fuel Save
Fuel loaded: 55.5l
Kms run: 844.99
FC: 15.22 kms/lit
Nitro +:
Fuel loaded: 54.9
Kms run: 814.7
FC: 14.84
It's only one test run. Although the stats are close, translates to 30 kms more per tankful.
I would think with gasoline, Nitro + is made with performance in mind so don't expect too much in economy.
November 8th, 2015 02:40 PM #217
Which translates to a 2.5% difference. Which is well within the margin of error considering all the factors involved in arriving at a particular FC. I can rerun the test and make VPD more efficient.
Heck, FS Diesel and VPN+ Diesel come from the exact same tank in the depot. Exactly the same base fuel. It only becomes VPN+D when you put additional additives.
The additional additives are supposed to improve engine responsiveness and help with a cleaner burn. Which is what all premium fuels (gas and diesel) claim anyway.
With gasoline, Shell uses different tanks, different base fuel, different additives. But from my testing, no difference in actual performance.
And let's not forget that Shell's fuel in most of MM is from Total's Manila Terminal, while those from southern MM are from Tabangao Refinery. So even if it's the same additives for VPN, the VPN in Alabang isn't identical to that in QC. Oh, and Total sometimes loads 95 RON but sells it as 91 RON when supply for 91 RON is short. So you can actually get VPN even if you just buy FS.
Sent from my SM-N910C using TapatalkLast edited by jut703; November 8th, 2015 at 02:46 PM.
November 8th, 2015 03:15 PM #218
November 8th, 2015 03:18 PM #219
That's true, which is why one test isn't enough. As the scientific method states, an experiment has to be verifiable and reproducible, and a sample size of 1 is never reliable. 😊
If you're referring to Shell, both Cavite and Alabang get from Tabangao Refinery.
I'm from the oil industry so I know a bit of which goes where. 😊
November 8th, 2015 04:21 PM #220
