View Poll Results: BEST Unleaded Fuel: Shell, Petron or Caltex
- Voters
- 126. You may not vote on this poll
Shell
40 31.75% -
Petron
45 35.71% -
Caltex
11 8.73% -
Total
4 3.17% -
Sea Oil
13 10.32% -
Uni Oil
9 7.14% -
Others
4 3.17%
Results 461 to 470 of 488
- 54,262
December 16th, 2018 09:32 PM #461i am of the belief that running the engine occasionaly in the highway at high speed, helps keep the engine clean. the so-called italian tune-up.
but this is assuming, there is nothing wrong with the engine, except "carbon build-up".
if there is something else that's wrong with the engine, no amount of complete fuel system cleaner, can fix it.
my opinion.
December 16th, 2018 10:06 PM #462
December 16th, 2018 10:08 PM #463
No. Magkaibang fuel talaga yan. Ron 88 na pure gasoline yung regular 91 while ron 92 yung usual 95 octane. Then nilalagyan ng ethanol sa depot para umangat yung octane. Then lastly yung additives.Sa Total din naman bumibili si Clean fuel so same lang.
December 16th, 2018 10:21 PM #464
December 16th, 2018 10:31 PM #465
- Nov 2014
- 454
December 19th, 2018 12:18 AM #466Gaano katagal ang aantayin for the result? Kung me tubig, void ba delivery?
Meron ako piangpapa kargahan indie from TH daw 5 pesos cheaper sa mga station sa amin, kahit na nung mga panahon na sunod-sunod OPH eh parang hindi nababago o untoi lang tinaas nila. Kaya lang parang me mali everytime na nagpapa karga ako, kaya itinigil ko na.
Balik ko lang yung Q ko na mas ok ba magpakarga sa mga newly opened na station(Big 3) dahil malinis pa yung underground tanker ?
- 54,262
December 19th, 2018 09:12 AM #467personally, i would avoid the new station, until the plumbing and tank had been cleaned of "imperfections" by multiple fills.
by the same token, i try not to fill up at a gas station that had just received its tanker delivery, to give the "settlements" time to settle down. it's probably not an issue, but as i can afford not to...
but that's just me.Last edited by dr. d; December 19th, 2018 at 09:20 AM.
- Nov 2014
- 454
March 22nd, 2019 10:03 PM #468
- 54,262
December 10th, 2019 03:30 AM #469what gas engine are you, po?
if the engine was designed for higher octane fuel, then it will function most efficiently using that higher octane fuel.
the computer can detune it a bit, so's it can use lower octane fuel, but i believe its power output will also be decreased a bit.
December 10th, 2019 05:34 AM #470
Itong 5 lang lagi nasusubukan ko.
Petron - XCS swabe hatak, best FC for me
Caltex - sakto lang hatak, ok din FC
Phoenix - average hatak / average FC
Seaoil - pinaka malakas hatak pero worst when it comes to FC
Shell - Kahit 95 octane ko bakit parang ang hina ng hatak, ramdam ko yung ingay ng makina compared sa iba ang lakas din sa FC
Balikan ko lang itong mga gumugulo sa isip ko kaya na-pa-reply ako sa thread na ito... was...
China cars
