Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Mar 2007
    Sa akin 34.64L talaga or 1,500 pesos. Nagpakarga ako kanina lamang super kaunti nalang talaga kasi natira eh halos di na umakyat ang gauge ko. Galing pa ako ng biyahe
    Sabi sa manual eh 42L daw. Pero nag stop na automatically yung machine nag click * 33.xxL pina puno ko nalang total ilang ml nalang kulang para maging 1,500
    so does that mean may reserve ako na 8L? madami pa ah
    Aug 2005
    Iyong Avanza J, ang nasa manual ay 45 liters ang gas tank, pero pag nag gas ako na nakailaw na ang low fuel indicator, nasa 36+ liters lang ang nakakarga go. Di pa ako umabot ng 37 liters.
    Mar 2007
    I see. nagtaka lang ako 34L lang ang liit hehe. minsan naman di pa umiilaw ang low fuel indicator eh malapit na sa empty. may aftermarket ba na digital gauge?
    For our 2 vans, 60L each.
    For our car, 40L.
    4303:gun:
    Mar 2007
    grabe 60L ang dami lol
    Dec 2002
    it really depends on the car but the reserve ng gasoline tank is about 8-10 liters . The low fuel warning indicator will light up when it reaches this level but it does not mean that you will immediately run our of gas. So when the light comes on you still have about 8-10 liters of fuel left in your tank...
    around 39 liters kung hindi auto-click pero sa manual 42 liters daw ang fuel capacity..
    Mar 2007
    now i understand. nakita ko sa manual na approx. 7.9L nalang daw natitira if the low fuel lights up. so it makes sense. 34 plus 8 is 42
    may naka experience na ba dito nang naubusan talaga ng gas? how was the experience? heheheh
    Jul 2003
    one day may hinatid lang ako sa may paranaque tapos pag tingin ko sa guage ko nakailaw na un low gas light tapos lampas empty na tlga... d ko lang napansin cguro. kaya hataw na papuntang gas station. 64L daw max sa 6 pero napakarga ko 64.xxL worth of blaze haha.
    Sa akin 60L (pag umilaw na fuel indicator). Pero sa manual nakalagay 62L.
    Aug 2004
    Ran out of gas once on a 70's Lancer on the highway... man, that was a looooooooooong way to push... :hysterical:
    I always run my car below "E". My reserve is about 8 liters, but I usually run the car down to within 2-4 liters of empty before refilling. Bad habit, I know...
    On more modern cars with trip calculators, it's easier. Sa Focus, I've driven it to within one and a half liters of empty without worries...
    Mar 2007
    lol. ang nakakatakot eh sa gabi tapos wala masyadong motoristang dumadaan hehe. tapos ala karing load nako.
    Nov 2006
    Dati, sira na ang gauge ng 70's na car ko. Pag naka 200 km na ako sa trip meter, full tank na dapat para di maubos ang gas. Dahil sa traffic wala pang 200 km ang natakbo ko, tumirik ang car. So, pinagawa ko na ang gauge dahil hindi pwede ang karkula lang.
    Biggest fillups so far:
    44li sa Impreza
    89li sa Sport Trac
    Jul 2006
    full tank ko 38L lang click na sya. ayoko ko kasing isagad since tumatapon eh
    sayang lang. GLi 97 corolla.
    guys confused lang ako eto talaga. diba sa fuel gage 2 yung line dun?
    yung super empty at yung nasa upper nya before the half.
    pano ba pagsinabing full empty talagang nakadikit na dun sa bottom line?
    tapos po yung reserve nya bukod pa dun? or yung reserve nya is yung line at
    the upper of the full empty mark?
    Sep 2005
    yung empty pag nasa E na.. tapos iilaw yung reserve light mo.. so may mga 8 liters pa yun..
    Sep 2006
    Quote Originally Posted by suysuy View Post
    On a Lancer Boxtype na SL '83 3 years ago-Paakyat na ako sa University parking lot (steep din kasi ang inclination) tapos biglang nmatay makina.. I didn't know the cause pero ugali ko din kasi na nagkakarga lang pag nasa "E" na..ayun nga naubusan..at isa pa kasi paakyat yon at yung natitirang reserve eh ang tendency umurong sa likod ng tank kaya di na mahigop ng hose ng pump..
    kakahiya nga kc nag cause ng traffic lalo na yung mga umaakyat tapos mabibitin sila dahil nakabalandra ako sa daan. May nainis pero meron din namang umunawa. Busina dito busina doon at yung mga guard naman eh titingin tingin lang.
    On top of that, kelangan ko bumili ng ilang litro ng gas at isa isang inilalagay sa tank. Siyempre center of attraction ako dun sa area na yon and in as much as I wanted to leave it there, I didn't have a choice.
    But my present car's tank capacity is 45L. One time, the gas fuel tank indicator lit up at nagpafull tank na lang ako and it was 44.xx Liters. So does it mean I only had 0.xxx left on my reserve tank?
    Jul 2006
    Biggest fill up ever done on my diesel was 18 gallons, nearly 70L. It was on R (our version of E) for quite a while but the light never came on. Yep, one more project to do...
    Man just a note to all those people who insist on running on fumes... It's actually WORSE for your wallet!
    When you run the tank down to empty, gasoline tends to vaporize. On older cars, especially if the seal on the filler cap isn't air tight you'll be losing fuel slowly over time. It also tends to make your remaining fuel less usable, because obviously your fuel pump and injectors don't like being fed combustible air. Most of the time, fuel that you could have used will end up getting released as vapor the next time you fill up.
    May 2005
    42 liters on my ride (that's what the manual says) although on the average, gas station trips costs me 34-35 liters worth of gas (auto fill-up lang).
    i'm always concious when it comes to fuel in the tank. After every full tank, i reset my trip meter. so aside from the warning light, i take notice of the distance i have run.
Ilang Liters Talaga Full Tank Niyo Sa Gasoline Station?
