WTF?! There's a P2.20 price increase??? :arghhh:
P23.50/liter at Omni Fuels Sandoval Ave. Pasig!!! :censored:
Total North Fairview P2 increase per liter bringing the cost now at P23.40/liter.
AMP... i just gassed up the other night at P 21.40 right after i saw the newspaper article on the LPG increase. Darn i miss the P18.00/L days from a few months ago; this will bring me to over 1K for a full tank again.
Kaso lang... its on the news again today that LPG prices would be raised.
Total North Fairview P25.40/liter - P1.50 hike.
How about in other areas? any price hike?
GASOLINK along araneta ave between Puregold, EROD and SOEN BLDG
(P27.25 as of 120309) less .50cents if you will not avail of promos just ask for the discount lane
credit card accepted
nagiging ginto na naman ang lpg. total alabang Php 27.++ as of Dec 3
Motor Octane Number (MON)
MON is designated to ensure adequate anti-knock characteristics of the fuel and
constrains the composition (to some extent) since olefins and some C4s[SIZE=1][SIZE=1]33 [/SIZE][/SIZE]have
relatively low octane.
Impact on Engine PerformanceThe Motor Octane Number (MON) can have a major impact on engine performanceambient temperatures.
and durability. A higher MON value allows engine design for a higher compression
ratio which in turn allows greater power generation and better efficiency. If the MON
value is insufficient for a particular engine, knocking or ‘pinging’ can occur,
especially when the engine is heavily loaded. This in turn can cause serious damage
to the engine.
A minimum MON is designated to ensure adequate anti-knock characteristics of the
fuel. For LPG, MON is more critical than the Research Octane Number (RON)
because of the higher combustion temperatures which occur with LPG in comparison
with petrol. Engine performance under these conditions correlates better with MON.
Also, because of the high sensitivity (difference between RON and MON) of LPG
components, if MON is adequately defined, then RON also will be adequate. The use
of MON rather than RON is consistent with international practice.
It should be noted that for generation 2 fuel systems, when autogas and air are mixed
there is no drop in temperature such as occurs when petrol is injected and evaporates.
These higher mixture temperatures promote knocking. This effect may be less
significant in regions of Australia which do not experience high ambient temperatures
during summer months, and allow somewhat lower MON requirements, as in Europe.
The effect, however, is more significant in regions in Australia which experience high
MON Constraint on Composition (Olefins)An olefin is a family of chemicals containing carbon-to-carbon double bonds. Olefins
are unsaturated hydrocarbons (such as propylene (propene) and butylene (butene))
and can lead to engine deposit formations and increased emissions of ozone-forming
hydrocarbon and toxic compounds. Olefins are oxidatively and thermally unstable and
may lead to gum formation and deposits in an engine’s intake system[SIZE=1][SIZE=1]35[/SIZE][/SIZE]. It is known
that combustion chamber deposits in petrol spark-ignition engines increase tailpipe
emissions of CO, HC and NOx.
[SIZE=7][SIZE=7][SIZE=2]SETTING NATIONAL FUEL [/SIZE][SIZE=2]QUALITY STANDARDS[/SIZE][/SIZE][/SIZE]
[SIZE=2]prepared by ENVIRONMENT AUSTRALIA[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]not all LPG stations here in the Philippines have the same level of Olefines in its LPG content, some have less than 1%, some can go as high as 30%[/SIZE]
Yup, there is a shortage of LPG in Manila because of two bridges connecting the Shell & Total LPG depots in Batangas is not passable.
Expect the shortage to continue until January.
At least we can switch to gasoline when we can't fill up on LPG.
http://www.philstar.com/Article.aspx?articleid=530801
[SIZE="5"]Dealers see shortage of LPG until February[/SIZE]
By Donnabelle Gatdula (The Philippine Star) Updated December 09, 2009 12:00 AM
MANILA, Philippines - Dealers of liquefied petroleum gas (LPG) said yesterday there is a shortage of cooking gas that may last until February next year.
LPG Marketers Association (LPGMA) president Arnel Ty said the supply of LPG from Tabango, Batangas has been disrupted.
“The two bridges in Tabango, Batangas are still impassable. There is totally no LPG withdrawal from Shell and Total,” he said.
“We expect that the supply shortage will affect the market for two months,” he added, but clarified that there has been no increase in LPG demand.
LPGMA members increased their LPG prices by P3.50 per kilogram this month, or about P40 increase per 11-kilo cylinder including value-added tax (VAT).
Prices of LPG rose P4 per liter in November.
An 11-kg cylinder tank of LPG will now cost P620 from P580 per tank.
Department of Energy price monitoring data showed LPG contract prices abroad reached $660 per metric ton in November from $589 per MT in October.
http://www.philstar.com/Article.aspx...bCategoryId=63
[SIZE="5"]Suppliers to take steps to cushion impact of LPG shortage[/SIZE]
By Donnabelle Gatdula (The Philippine Star) Updated December 10, 2009 12:00 AM
MANILA, Philippines - Major suppliers of liquefied petroleum gas (LPG) are set to implement contingency measures to cushion the impact of the prevailing supply shortage of cooking gas in the face of the failure of government to give a firm commitment to repair the damaged bridge in Batangas where trucks from the gas depot pass.
The country’s largest LPG suppliers include Petron Corp., Pilipinas Shell, Total and Liquigaz.
Total president and managing director Ernst Wanten told reporters at the launch of the “Total Day of Service” that efforts would be made to ensure that LPG will reach consumers.
“We are almost ready. I think in a couple of days, we can have a solution where we can have a mobile bridge – a system where we can move the trucks again. We put highest priority in fixing the bridge,” Wanten said.
Wanten expressed optimism that the LPG supply problem would not escalate.
“(The bridge repair) will take three to six months or maybe it will take longer so we need a viable solution for the longer term, so that’s why we are (implementing a solution) without compromising the safety specially since LPG is a dangerous product,” Wanten said.
The Bridge of Promise in Tabangao, Batangas, where an LPG terminal being used by both Total and Shell is located, collapsed a few months ago due to past typhoons but the Department of Public Works and Highways (DPWH) has not completed the repair of the bridge.
The Department of Energy has already been coordinating with the DPWH to expedite the construction of the bridge and the possible reinforcement of the alternate bridge in Taysan town.
Wanten sought the cooperation of all concerned parties to minimize the impact of the supply shortage on consumers.
“We are a bit more confident and more hopeful that we get this sorted out. We talked with the authorities. They tried to help us as much as possible but it’s not an easy task,” he said.
Total LPG manager Dino Cuaycong, on the other hand, said they have been managing to supply the needs of their customers but with some delay.
“In the last two weeks, we are looking for other avenues to source our products locally. As of now, we are prioritizing customers with standing commitment. And there are some delays. So far, we were able to service our regular customers. We have other options that we are looking at this week. We hope to bring everything to speed within a week or so,” Cuaycong said.
Cuaycong gave assurance that Total would try to absorb any price impact that the LPG shortage would bring.
“No, we don’t see any effect on the prices we have now, at least from our end. Of course it has effects on our margins because we have to spend a little more to make the products available,” he said.
Asked if they would continue to absorb the price impact until the problem is resolved, Cuaycong said, “Yes, ideally yes.”
Shell spokesman Roberto Kanapi, meanwhile, said they expect that the government’s solution to the problem will be completed soon.
“Reinforcement target completion is by end-month. Further, Taysan Bridge reduced load limit. As a result, supply disruptions may be likely in the days to come so we’re looking at contingency arrangements. We continue to work with the government to ensure quick resolution,” Kanapi said.
Shell expects the delayed shipment of LPG to have a slight impact on prices.
“We have to study the impact on prices, but there may be some movement,” he said.
Petron sources, meanwhile, said the company is trying to service the needs of other customers of Shell and Total.
Arnel Ty, president of LPG Marketers Association (LPGMA), earlier said if solutions were not carried out, the prevailing supply shortage of cooking gas would linger up to early 2010.
“We expect that the supply shortage will affect the market for two months,” Ty said.
LPGMA increased their LPG prices by P3.50 per kilogram this month, or about P40 increase per 11-kilogram cylinder including value-added tax (VAT). Prices of LPG were increased by P4 per liter in November.
This would increase prices to P620 per 11-kg cylinder tank from the present LPGMA selling price of P580 per tank.
The LPGMA official warned that this shortage would result to more increases in LPG prices.
“In the dealers and outlets side, it (prices) will go up,” he said.
Based on Department of Energy price monitoring data, LPG contract prices abroad reached $660 per metric ton in November and $589 per MT in October.
P26.50/liter at Omni Fuels, Sandoval Ave. Pasig
At long last! Nag roll-back, kahit kaunti lang.
Total AutoGas - Makati P26.50
Manila AutoGas - Makati P27.00
Total AutoGas - Fairview P27.10![]()
