Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Jan 2016
    Need enlightement from car owners who have tried these two. Ano po ang advantages and disadvantages?
    Wala. Tried both. Same experience.
    i ilke this guy;
    Quote Originally Posted by benchman View Post
    i ilke this guy;
    10 reasons not to use nitrogen. I only need 1 though, tamad ako maghanap ng refilling station, dun lang ako sa pinaka malapit na gas station, haha.
    likewise hahaha
    i once read an article by an auto "authority": "the advantage of nitrogen over oxygen is so minimal, it would only be truly but still minimally advantageous in ordinary daily use, if it were free".
    and this does not yet account for the time, effort and fuel spent in going out of your way to that free refilling station.
    the reason nitrogen is prefered in some applications, is because it, unlike oxygen, does not support fire.
    True. Hirap maghanap. Go out of ur way... To pay 50 bucks per tire. Ugh!
    Aug 2012
    Another nitrogen thread. A simple Google search will tell you all you need to know.
    I use ordinary air. I have my own portable tire inflator in the car. Makes life simple.
    Sent from my D5833 using Tapatalk
    May 2009
    Quote Originally Posted by Cookiesun View Post
    Below are the ff. reasons,
    a. Nitrogen like CO2 are inert gas and does not support fire or overheats.
    b. Nitrogen is lighter than oxygen.
    c. Nitrogen is colder and therefore expands less.
    If you are not carrying heavy loads on a daily basis, race for a living or tow heavy loads, stick to ordinary free oxygen. It will make your life less complicated.
    Air is composed of 78% Nitrogen, 21% Oxygen, and 1% other gases.
    Why pay extra for something that is already free?
    Apr 2016
    no problem with nitrogen air have been using it for the last 5 years mga P50 per tire lang then pwede naman ordinary air for maintenance so far wala naman effect sa tire and sa ride parehas lang
    Apr 2006
    never had a problem using ordinary air for my tires. less complicated. less hassle.
    I used Nitrogen for one reason: air pressure doesn't drop down as fast. (i only need to air up every 3 months or so), and i air up it a place that is convenient (S&R).
    Aug 2004
    I air up in an even more convenient place.
    My garage.
    Pumping four tires to 55 psi by foot is good exercise.
    Aug 2004
    ... and i air up it a place that is convenient (S&R).
    Free refills right?
    55?
    Mar 2004
    Pumping them by hand is even better ... used to do it using air compressor but it took longer to set it up and store it compared to just using a hand pump ...
    Aug 2012
    Sa garage lang din ako mag refill. I use automatic digital tire inflator. With normal air, you lose 1psi per month. Adding air once a month is not difficult to do.
    Jul 2013
    Have you seen how they put nitrogen into your tire?
    The last time I have our wheels replaced, there is a free nitrogen fill using a quite big (as in refrigerator size) machine.
    However, the tires were not evacuated of ordinary air. So I am not actually sure if it'll work knowing it is not pure N in your tires.
    Not with regard to expansion of gases/change in tire pressure as temperature changes, I dont think we have that much of temperature fluctuation in our country compared to what other countries or car racers' tires experience to really benefit from Nitrogen.
    If its free why not!
    Since I always get free refills and dun din naman ang suki ko na vulcanizing shop binabalik balikan ko din.
    Jul 2006
    Isn't air (this thing we are breathing in) about 70-ish% nitrogen?
Nitrogen vs Air in Tire
