Results 1 to 10 of 4200
    hello everyone!
    newbie here
    alin po kaya ang pinaka-ok na lpg conversion company?(when it comes to service, technology, aftermarket support, etc.)
    which one offers computerized diagnostics, tuning, dyno, etc.?
    Quote Originally Posted by s0nnyb0y View Post
    hello everyone!
    newbie here
    The best auto-LPG kit is the sequential injection LPG system, which basically a individual port fuel injection system for LPG. It even gives your engine a slight boost in power as compared to running on gasoline. Downside is it cost at least twice as much as the typical LPG system available at NAIADSS or other LPG installers.
    NAIADSS price for 1.6L EFI conversion is around P28K.
    You have a budget in mind for your LPG conversion?
    Sep 2006
    Can the EFI version be installed on carburator engines? Thanks!
    Quote Originally Posted by smdelfin View Post
    The LPG kit for EFI engines and carb engines are almost the same (given the Korean type conversion kits). The difference is the injector bypass box which disables the engine's fuel injectors if you are running on LPG. If you dont have fuel injectors, there is nothing to bypass.
    There is the Italian EFI LPG kit that costs at least P60K. I dont think you can fit that to a carb engine either because I think it takes the stock injector signals for fire it's LPG injectors.
    which company offers sequential injection kit?
    plano ko po kasi kumuha ng car tapos gawin ko taxi. mas ok po ba in the long run ang sequential?
    Sequential injection is probably applicable to higher-end fuel injection cars. If you are simply getting a 1.4L car, you would be better off with the standard carb type LPG kit which costs roughly P24K.
    If I am correct, Landrolanzo (tama ba spelling??) sells them.
    sino po si landrolanzo? any contak number?
    Anyway, I got the contact info for TARTARINI kits... they have what you want... don't be shocked at the prices though.
    West Orient Corp
    Tel 641-4473 / 09178818800
    is it advisable to have a brand new car (tucson) converted right away. I was thinking of tartarini. Is there a comparable brand for this type of lpg conversion. tartarini costs 60k + evat.
    thanks
Auto-LPG Conversion Thread
